Help!!! Cant Read Tire Pressure on door!
Login | |
Help!!! Cant Read Tire Pressure on door! - 6/13/2008 4:58:51 PM
86flowmaster
Score: 0 Joined: 6/13/2008 Status: offline
I have a stock and well maintained 1986 Camaro Z28 Iroc-Z with the 305 and i cant read the freaking tire pressure chart on the side door and i dont remember were the manual is or anything... could someone tell me what it is on theirs.. i dont care as long as its 3rd gen z28 iroc. help please!! and thanks!
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 6:39:36 AM
black89rs
Score: 0 Joined: 7/24/2007 Status: offline
look at the tire
_____________________________
if it growls it aint no mustang
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 8:15:32 AM
MadMikeZ28
Score: 0 Joined: 7/15/2006 Status: online
^^X2 The vehicle manufacture or door does not know what kind of tire you replaced the originals with. The tire manufacture would know what pressure to use for their technology and thats why they put it on the side.
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 8:20:46 AM
86flowmaster
thats what everyone does wrong.. you dont read the side of the tire because it will just tell you the maximum pressure which is some where around 44. the tire pressure is on the door or somewhere else inside everycar.. doenst matter what kind of tire.
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 8:31:23 AM
MadMikeZ28
You are way off on that theroy. Lets say your OEM tires were a three ply sidewall and you replaced them with a cheaper more affordable two ply. The door sticker could show a higher pressure for the tires than the max pressure on the tires themselves. Looking at the door sticker could be where foord owners went wrong. The sticker recomended too low a pressure for the tires and weight of the suv''s.
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 9:23:11 AM
blackz87
Score: 0 Status: offline
You can not go wrong using 32/35 PSI....
87 Black IROC-Z28 350 Crate with TPI original owner
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 9:37:44 AM
Camaro 69
Score: 0 Joined: 10/17/2007 Status: online
86 & M.M., you''re both right....sort of. A tire that is properly suited for the car that it''s installed on will fit within the pressure requirements established by the manufacturer. Recommended pressure on my 91 (door sticker) is 30 F/R. But, I always put in more than recommended in all my cars. My tires are rated at 44 MAX, and I try to keep around 36 psi in the tires. I like to put a little more than listed mostly to get better gas mileage (less rolling resistance), and to also have a little buffer-zone for any small amount of air loss. Maxing out the tires pressure isn''t the best idea for a few reasons: 1) It makes the car ride like a truck. Being able to roll over a dime and tell if it''s heads or tails isn''t the best for comfort! 2) Overinflating can cause more excessive wear on the center of the tire, wearing it out before it''s time. 3) An overinflated tire puts your tire-to-pavement grip more in the slicker than shiit zone. A hard tire won''t squish & roll as much around a turn, which you may think is better for more stability, but you''re actually left with less rubber on the road. So I would go with somewhere in the middle, between the car''s recommended and the tires max pressure. That was an easy answer, eh?
< Message edited by Camaro 69 -- 7/1/2008 9:52:16 AM >
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 10:55:58 AM
black89rs
hey camaro .....it took a lot of words to say don''t over inflate your tires.....i also use around 36 psi in mine......but it depends mostly on what kind of tire and how you like your ride..(bumpy or smooth)
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 12:19:13 PM
86flowmaster
true that.. if my rims are the same size they were and the tires are the same width.. than it should be what the car says. and yah matters where you live too cuz the tire pressure can change everyday from air temp.
RE: Help!!! Cant Read Tire Pressure on door! - 7/1/2008 12:44:40 PM
Camaro 69
quote:
ORIGINAL: black89rs hey camaro .....it took a lot of words to say don''''t over inflate your tires..... Yeah, I know. But then the next ? would have been....Why?
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
