Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
stereo wiring draining battery
  Printable Version
Camaro >> Brand Review >> Audio/Visual Electronics >> stereo wiring draining battery Page: [1]
Login
Message << Older Topic   Newer Topic >>
stereo wiring draining battery - 6/16/2008 2:22:40 PM
HEAVYCHEVYMAYNE.
Status: offline
so im planning to purchase a 1974 camaro from my uncle, but the thing is, he took it to a "buddy" to have his new deck hooked up, and now the battery drains when its off and has to be charged before every start. i dont know a lick about stereos or wiring so if anybody has some suggestions of what it could be please let me know. is this a simple fix?
_____________________________
1971 RS. 350/350.
Post #: 1
RE: stereo wiring draining battery - 6/25/2008 10:24:52 AM
LT1RUNNER
Status: offline
I have never heard of or witnessed a deck that would drain the battery so I''''m thinking that there may be another cause to the battery drain.  But if you would like to check out the install it''''s very simple.  GM has used the same wire color to designate hot wires from ground wires for the longest time so what you can do is pull out the deck.  GM uses the following.......
Yellow - always a hot wire.
Orange -  a switched on hot wire.  Done by turning the key to the accesory position.
Red - also an accesory type hot wire.
Black - ground
Look at the wiring on the deck and like the wires above most stereo''''s have their wireing the same with a few exceptions. (I''''ve seen blue used as a always hot wire on rare occasions.)  Simply match up the wires and you should be good.  Hope this helped.
< Message edited by LT1RUNNER -- 6/25/2008 10:35:19 AM >
94 Z28
Edelbrock heads
Edelbrock cam
Edelbrock headers
Proform rockers
Flowmaster cat back
Cold air intake
PCMforless
http://i448.photobucket.com/albums/qq203/Perea14_2008/ATT173192.jpg
(in reply to HEAVYCHEVYMAYNE.)
Post #: 2
RE: stereo wiring draining battery - 6/30/2008 6:45:52 PM
73camaroSS
Status: offline
73camaroSS's photo gallery
is the stereo on all the time like when you have the key out you can still play the stereo,if you can then who ever hooked it up did not use the stock wiring,they hooked it up to a source that is all ways on what you want to do is figure out were all the wires are hooked up and see were the HOT wire is hooked up to and try to find a source that turns off with the key.
U.S.A. 1, love it or leave it. Muscle4Life!
Ford hahahaha. They Circled The Problem
http://www.youtube.com/user/73camaroSS
(in reply to LT1RUNNER)
Post #: 3
RE: stereo wiring draining battery - 7/1/2008 4:29:07 AM
carnage9
Status: online
e thing was happening to my 96 camaro after i installed my stereo, what it might be is just your battery with a bad cell as it was in my case, this often happens when installing pionner decks because of there weird harnesses on higher end decks, dont ask me why but try to get your battery tested first.
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Brand Review >> Audio/Visual Electronics
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5471
spectergt2603748
madmikez283673
95slvrz282797
74454bb2688
cplthomas2449
bluovlh8er2403
blade2299
02stangt2236
ninetysixyen2072
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
K&N Engineering, Inc.
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
