Engine swap 4 87 Z
Login | |
Engine swap 4 87 Z - 6/18/2008 10:32:35 PM
Jmaro313
Score: 0 Joined: 6/18/2008 Status: offline
I have an engine that needs to be machined but to save money I was going to swap it out for a running engine out of another car, can I go with an older block? Say, an 86 or 85? All help is appreciated... Thanks in advance...
RE: Engine swap 4 87 Z - 6/19/2008 7:00:08 AM
86Z350
Score: 0 Joined: 10/1/2007 Status: offline
The only thing with older blocks to remember is the heads are different. GM Blocks 197?-1986 used the same heads with 4 outside bolts for the valve covers. 1987-19?? used heads that have a center bolt design. That and the water jackets wont line up the same. If you get a long block, you can go that route. I think they started using a better cam in the later years if I''m not mistaken.
RE: Engine swap 4 87 Z - 6/22/2008 8:59:58 PM
Z28midwest_08
Score: 0 Joined: 11/21/2007 Status: offline
I''m not sure what years are different but intake bolt patterns can be different as well between certain years. I got a hold of a 350 block from an older guy once, never actually ran the numbers, but I had to slowly drill out the center four bolts on a holly intake to fit it to the motor so just watch out for that.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
