Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Trans Help???
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V8 Tech >> Trans Help??? Page: [1]
Login
Message << Older Topic   Newer Topic >>
Trans Help??? - 6/19/2008 11:14:29 AM
luvchevys5500
Status: offline
Hello       I have a 86 z28. It came stock with the 305 and 5 speed trans. The kid I bought the car from swapped to a 350 and put a 700 r4 in. Since I''ve had the car I had to put another 700r4 in because I burnt the other one up and this one feels like its about to go too. I replaced the rear end with one from a 2.8 87 camaro. I''m on the second trans and the third rear end. Now my questions. Is this rear end going to work? And what can I pull a T5 from that would work with a 350? I''ve herd I can use one from a chevy 1500. Or should I stay with an auto trans?        Thank for the help..
Post #: 1
RE: Trans Help??? - 6/19/2008 11:43:35 AM
MadMikeZ28
Status: online
Sounds like you are just too hard on vehicles.
As for the T5 any will bolt up to the manual bell house. But you need to find a later one like 88+ because they are stronger. You also have to look at the shifter location as if memory serves they are in different locations for different applications.
But if you are going through rear ends and trannys then you are either getting junk or abusive and a T5 is not a fix for abuse
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to luvchevys5500)
Post #: 2
RE: Trans Help??? - 6/19/2008 8:40:32 PM
Camaro 69
Status: online
Proper adjustment of the TV cable on a 700R4/4L60 is critical. Maybe that''s why the transmissions are frying up?
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5502
spectergt2603830
madmikez283738
95slvrz282900
74454bb2688
02stangt2504
cplthomas2473
bluovlh8er2416
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
