Camaro 69
If there''s no way of getting a copy, then an air chisel would be my next attempt. Make sure it has a good edge on it. Catch it in one of the teeth of the lug nut and aim it in the direction of spinning it counter-clockwise. It should spin it right off. You may also be able to do it with a hand chisel and hammer, but air will be a lot easier. That''s also a good trick for getting off nuts or bolts with a rounded-out head.
_____________________________
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
