Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
gettin hot!!
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V8 Tech >> gettin hot!! Page: [1]
Login
Message << Older Topic   Newer Topic >>
gettin hot!! - 6/28/2008 12:40:30 PM
vabeachxj
Status: offline
ok we just got done rebuilding the top end of my 89 rs  when we went to turn it over it don''t want to start and the grounds are getting way hot i don''t know if i am missing something but i can''t find any wires i missed hookin back up but i think there was 2 or 3 wires on the drivers side ground but i can''t rem and i only have 1 hooke d up any help would be nice
thanks
Post #: 1
RE: gettin hot!! - 6/28/2008 1:14:34 PM
MadMikeZ28
Status: offline
you have the ground on the back of the head to the firewall? Then there is the main battery ground which should go some where to the engine (depends on what year where but as long as its on there its good) and a 10 gauge to the chassis
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to vabeachxj)
Post #: 2
RE: gettin hot!! - 6/28/2008 3:39:42 PM
vabeachxj
Status: offline
ya we didn''t mess with the battery ground or the one to the chassis all we pulled off was the 2 going from the heads to the firewall
(in reply to MadMikeZ28)
Post #: 3
RE: gettin hot!! - 6/29/2008 9:31:01 AM
Gorn
Status: offline
Gorn's photo gallery
 Based on your post I would guess the valves are too tight and the starter is not strong enough to turn the engine over. Did you replace the valve springs? Might want to check they gave you the right ones. Back the valves off and see how it cranks. You need to test your starter draw to see if its within spec.
Of course there are a lot of other things that it could be. Even the fact the car sat for a few day could have let a connection that was starting to go bad to get bad enough to effect the starting.
< Message edited by Gorn -- 6/29/2008 9:44:56 AM >
67 RS/SS, 350/4 speed, 12 bolt, Power top, Full gauges
Dingers Build Thread
Post #: 4
RE: gettin hot!! - 6/29/2008 10:50:37 AM
vabeachxj
Status: offline
we did not replace the valves they all looked good very min wear we are gona run a comp test tomm and prob reajust the rockers to make sure we did not over tighten them
(in reply to Gorn)
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 3rd Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5507
spectergt2603834
madmikez283764
95slvrz282914
74454bb2688
02stangt2554
cplthomas2487
bluovlh8er2418
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
