RE: True Dual? ?
Login | |
RE: True Dual? ? - 7/2/2008 4:25:39 PM
evilkal
You can do it... It''s gotta be custom... There aren''t any kits for it but it can be done (I''ve done it before).
RE: True Dual? ? - 7/2/2008 4:36:39 PM
Alih
Joined: 6/5/2006 From: Toronto, Ontario Status: online
whats the point in true duals on a v6 ? it wont make a difference unless your making 400+hp
_____________________________
''93 Z28 "Primered Wonder" ''02 Blazer LS Coupe "Without death, life is meaningless"- Dave Mustaine There are two things in life, Mind and Matter. I dont Mind, and you dont Matter
RE: True Dual? ? - 7/2/2008 4:39:57 PM
evilkal
It sounds completely different???
RE: True Dual? ? - 7/2/2008 5:16:36 PM
Camaro 69
True duals....you mean like this? And if you can do it for an 8 you can for a 6. Same car, just different engine/header crosspipe. Sure it''s a custom job, but if you can find a small independent exhaust guy, you''ll probably spend less than you would on one of those "gotta have" exhaust systems on the market.
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
RE: True Dual? ? - 7/2/2008 5:31:49 PM
Alih
yes it sounds different, but it wont help performance much unless you are pushing some real hp numbers
