Car won''t crank
Login | |
Car won''t crank - 7/2/2008 10:50:55 PM
camarohelp
Technically this post might not really belong in this forum, because it concerns a 1986 Trans Am...but since camaros and firebirds are practically clones I thought I''d try here since the firebird forums I''ve found aren''t quite as active. 1986 Trans Am, 4 bbl 5.0L manual The car usually runs without a problem; today my brother was out driving it and suddenly the tach and speed gauges started jumping up and down and the engine started running really rough. He pulled over, shut it off, and couldn''t get it started. Here''s the strange part: the dome lights worked, the alarm worked, but none of the usual gauge lights (back lights, check engine light, etc) lit up when the key was turned into the on position. In fact, if the dome light hadn''t been on, you would have thought the battery was disconnected. The engine wouldn''t crank. We disconnected the battery, poked around under the hood, didn''t find anything strange, reconnected the battery, and the car started up (although it was a very rough start) and drove almost perfectly the rest of the way home. Any ideas?
