Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Big missfire problem!
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> V6 Tech >> Big missfire problem! Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Big missfire problem! - 7/4/2008 7:26:16 AM
Jay from Holland
Status: offline
Hi guys,
jay from holland here and my 3.8 started to missfire on cyl. 6
one month ago.
I printed out some topics from this forum with the same problem and gave it to the meganic so he could follow this but now after a month the car is still not running.
When cold it runs fine, after 2 or 3 min. the problem begins.
If it was only cyl. 6 the car should be running on 5 cyl but mine stops and moves very slowly running on maybe 2 or 3 cyl. (feels like that) CES light comes on, flashes sometimes.
He checked everything that you guys talked about, plugs,cables,injectors,MAF,installed a new distributor, checked compression, enc enc but still nothing.
Is there anybody who has some more idea`s?
bc i run out..
thx
Post #: 1
RE: Big missfire problem! - 7/4/2008 11:47:47 AM
Bowtie Or No Tie
Status: offline
Well You Need 3 Essential Main Things For An Engine To Run:
1. FUEL.
Have You Checked Your Injectors?
Does Your Fuel Pump Work Properly?
Do You Have Access To A Fuel Presser Tester?
2. SPARK.
You Said You Replaced The Plugs, Wires And The "Distributer" DSI, And It Cranks & Turns Over But Runs Poorly.
DEAD CLYINDER? MAYBE?
3. COMPRESSION.
Have You Done Any Sort Of Compression Test? If So, What Are Your Numbers?
~Also, What Is The History Of The Motor/Car?  Did You Just Get It? What Year Is It?
&& What Codes Does It Throw?
-If You Havent Found Out What Codes It Throws, If Its Pre-93, Put A Bent Paper Clip Into The (A) Pin And The (B) Pin And Your PCM Will Flash The Codes.-
~Heres How To Get The Codes If Its A 95.
http://www.camaroforums.com/m_128940/tm.htm
~This Is To Tell You What The Codes Mean
http://www.stengel.net/diccodes.htm
Hope This Helps.
_____________________________
quote:
ORIGINAL: BigNic
"oh how bout a new rear end so your not sending 500 horse to one wheel"
"93 Black Base Model L32
90 Corvette Rims W/ Eagle F1s
PaceSetter Headers
Dynomax Catback-Super Turbo Muffler
(in reply to Jay from Holland)
Post #: 2
RE: Big missfire problem! - 7/4/2008 11:52:50 AM
evilkal
Status: offline
Hmm... Check out your EGR valve?
(in reply to Bowtie Or No Tie)
Post #: 3
RE: Big missfire problem! - 7/4/2008 11:59:28 AM
evilkal
Status: offline
Also check your catalytic converter. It may be stopped up
(in reply to evilkal)
Post #: 4
RE: Big missfire problem! - 7/4/2008 1:23:24 PM
z28pete
Status: offline
z28pete's photo gallery
You mentioned that your mechanic replaced the distributor. Engines in 3.8 Camaros do not use distributors. Your car uses DIS ignition with 3 coils, each coil firing 2 spark plugs. If #6 cylinder is misfiring due to a coil problem, the mate cylinder #3 will also misfire. Otherwise follow what was previously posted.
Pete
Post #: 5
RE: Big missfire problem! - 7/4/2008 4:17:55 PM
Jay from Holland
Status: offline
Guys i did..
and in Europe, the junkyard guys know more about the engines than the dealers do bc they work with those engines all the time.
Some plugwires were old and gave a bad spark, replased, but still my car doesnt run well.
Could it be my main computer?
they dont break down often..
(in reply to z28pete)
Post #: 6
RE: Big missfire problem! - 7/4/2008 9:13:31 PM
evilkal
Status: offline
DId you check your EGR and catalytic converter like I said? What about your coils? Stopped up cat doesn''t throw any codes except the P0300 codes when it bogs it down WHEN IT GETS HOT. Sounds like your problem to me... I''m just advising that you check it.
Post #: 7
RE: Big missfire problem! - 7/5/2008 9:19:08 AM
Bowtie Or No Tie
Status: offline
I Totally Agree With Evilkal Check The EGR & The Cat........
Did You Get Any Codes From It?
quote:
ORIGINAL: BigNic
PaceSetter Headers
Post #: 8
RE: Big missfire problem! - 7/5/2008 3:43:18 PM
Jay from Holland
Status: offline
Thanks alot for all the tips,
im going to work with it monday and if i find something
or have more questions i`ll post them.
Thanks again guys.
Post #: 9
RE: Big missfire problem! - 7/5/2008 3:45:35 PM
Jay from Holland
Status: offline
mine`s a `97 3.8
i`ll try to get the codes.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 4th Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5507
spectergt2603838
madmikez283771
95slvrz282916
74454bb2688
02stangt2564
cplthomas2489
bluovlh8er2418
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
