Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
87 IROC No tach
  Printable Version
Camaro Forums >> General >> General Tech >> 87 IROC No tach Page: [1]
Login
Message << Older Topic   Newer Topic >>
87 IROC No tach - 7/4/2008 1:03:29 PM
shortyroc59
Status: offline
    87, 305 tune port IROC, tach stopped working.  New tach, module, and coil.  Checked the voltage coming off the coil and the distributor and seems to be fine.  Any suggestions from here.
Thanks, Shortyroc59
< Message edited by shortyroc59 -- 7/4/2008 1:17:06 PM >
Post #: 1
RE: 87 IROC No tach - 7/4/2008 2:57:19 PM
MadMikeZ28
Status: offline
There is not much to it. A power wire that also sends power to other gauges so if they work then that should be fine. Ground wire which also supplies other gauges and a white wire from the coil which is the signal wire. Posible the plug on the coil went bad. Sopme times the wires are bent real bad and may eventualy get a short in them.
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to shortyroc59)
Post #: 2
RE: 87 IROC No tach - 7/11/2008 6:52:41 AM
shortyroc59
Status: offline
Thanks for the info.  I think it''s my remote starter thats'' cutting out the tach because everything else is new and when I bypass the ignition system and take the tach out of the car and wire it directly it does work.
(in reply to MadMikeZ28)
Post #: 3
RE: 87 IROC No tach - 7/11/2008 2:45:09 PM
MadMikeZ28
Status: offline
good posiblity
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> General >> General Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
