Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
electric fuel pump and carb problem
  Printable Version
Camaro >> Brand Review >> Computer & Fuel Systems >> electric fuel pump and carb problem Page: [1]
Login
Message << Older Topic   Newer Topic >>
electric fuel pump and carb problem - 7/4/2008 5:25:50 PM
sewerrat
Status: offline
I have a friend with an 87 firebird with a carbed chevy 350. The recently rebuilt engine has a 750 holley, vac advance dizzy, and is feed with a holley electric fuel pump. The car will run poorly then stall when the engine reaches normal operating temp. We''ve noticed it stalls only in town and has no problems on the open highway. He has a fuel pressure gauge on the carb inlet line. It reads 7-8 psi when engine running and drops off to nearly 0 when about to die. You can hear the fuel pump''s sound slows down when stalled. We''re thinking that the fuel pump is creating to much pressure during in town driving and probably fighting it self causing the pump to fail, thus stalls. If you let the car cool off or take a wet rag to the pump it will fire right back up again until the pump overheats again. We got a replacement pump from the autoparts store thinking it was defective but the new pump resulted with the same symptom. A friend suggested that we run a circulating return line back to the tank to relieve exessive pressure during low speeds. I just want your thoughts before he spends anymore $$ on this problem. Do you think the pump is loading up? What type of regulator with a return would be the most practical? thanks
Post #: 1
RE: electric fuel pump and carb problem - 7/5/2008 12:36:29 AM
Camaro 69
Status: online
I would definitely install a return style regulator. It will help the pump run smoother, and can also prevent vapor lock. The pump''s pressure is being "held back" by the present dead-end regulator. But the bypass/return line will divert the excess fuel back to the tank allowing the pump to work at a more constant rate.
http://store.summitracing.com/partdetail.asp?part=MAA%2D4309&view=1&N=700+150+4294880914+4294891681+4294880896+4294902722+4294849160+
_____________________________
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
(in reply to sewerrat)
Post #: 2
RE: electric fuel pump and carb problem - 7/6/2008 2:15:56 AM
sewerrat
Status: offline
Thanks for the link
(in reply to Camaro 69)
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forum >> Brand Review >> Computer & Fuel Systems
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
