Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
oil build up on intake valves
  Printable Version
Camaro Forum >> General >> General Tech >> oil build up on intake valves Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
oil build up on intake valves - 7/5/2008 7:44:40 PM
69RSSS
Status: offline
I have a 69 camaro with a 350, stock cast iron heads.  I have an issue with oil build up on the intake valves.  I had the heads rebuilt 2 years ago they have about 4000 miles on them.  The #2, #6 plugs had a lot of oil build up are were fouling out.  I''ve attached a picture of the heads and the cyclinders.   I did a compression check on all 8 cyclenders.  Each cylinder held 140-150 psi for 10 mins with no leak down.  I don''t really know where to go with this. If I get the heads rebuilt again I''m concerned this is just going to happen all over again.  Any suggestions would be apprciated.
Thumbnail Image
Thumbnail Image
Attachment (2)
Post #: 1
RE: oil build up on intake valves - 7/6/2008 7:54:19 AM
JRs72RS
Status: offline
Do you see smoke when you first start the engine? Also, it looks as though none of the cylinders are burning properly. First, if there is smoke at startup, it may be bad valve guide seals. If the rebuilder used OE style o-ring seals then replace them with Teflon seals, they are much more reliable. CAUTION: If the guides were replaced they might be too tall for this and it will require trimming the guide height. If you do not the seal will get crunched between the spring cap and guide. This is especially true when running a high lift cam. (Did you cam the engine and NOT let the head builder know your lift?) Since all cylinders look dirty, how about mixture and plugs? Get the carb mix correct and check it by reading the spark plugs. A rich mixture will leave unburned fuel in the cylinder and accelerate fouling. Check the entire ignition, make sure you are getting all the spark to the plugs. As a last resort you can step up to a hotter set of plugs.
(in reply to 69RSSS)
Post #: 2
RE: oil build up on intake valves - 7/6/2008 5:41:12 PM
69RSSS
Status: offline
I didn''t notice smoke on start up.  I did give the cam specs to the head builder. The cam is .488 intake .510 exhaust.
Maybe I do need hotter plugs but first I need to figure out what to do with the heads and the block.  I''m running a Mallaroy ignition.
(in reply to JRs72RS)
Post #: 3
RE: oil build up on intake valves - 7/8/2008 10:59:06 AM
73camaroSS
Status: offline
73camaroSS's photo gallery
what are you driving habits, do you take the car out and drive it intell it warms up and do you putt around or do you drive it like it you stole,you could have a lot of carbon do to not letting the motor warm up enough when you drive it,and every motor needs to have the crap ran out of it every once in a while to clean the all crap out of it. oh and what kind of oil do you use you might want to find a oil that helps get rid of build up and all so what brand of gas do you use.
_____________________________
U.S.A. 1, love it or leave it. Muscle4Life!
Ford hahahaha. They Circled The Problem
http://www.youtube.com/user/73camaroSS
Post #: 4
RE: oil build up on intake valves - 7/8/2008 3:55:09 PM
69RSSS
Status: offline
Well, you probably have a good point there.  I probably drive it like grandma most of the time.  I use Valvoline oil.  I gues atthis point I should have the heads cleaned up before it gets put back together.
Is the only way to tell if the carb is not too rich to check the plugs after driving it for awhile?  The engine starts up very easily, idles well and was running good unitl I notices a little miss one daythen I pulled the plugs
Attached is a picture of the #2 plug.
Attachment (1)
(in reply to 73camaroSS)
Post #: 5
RE: oil build up on intake valves - 7/8/2008 4:16:50 PM
73camaroSS
Status: offline
wow there is no way thats from driving it like a grandma, that is a very oil fouled plug,you should go talk to the guy that did you heads and ask him what the hell cuased that and see if it was his fault by not building them right or if it is something more serious. wow i just cant beleave how fouled that plug is.
Post #: 6
RE: oil build up on intake valves - 7/8/2008 4:46:25 PM
JRs72RS
Status: offline
That is one nasty looking spark plug!
One more question I have. The original post says oil build up on intakes. Did you take an intake valve out and look at the backside of it? Oil buildup there is a sure sign the seals are leaking.
Back to the spark plugs. The picture looks as though you are running .035 gap and the plug really does look like it is a range too cool. With the mallory ignition did you get a hotter coil? With a good coil you should run .045 gap.
Post #: 7
RE: oil build up on intake valves - 7/8/2008 6:56:15 PM
69RSSS
Status: offline
That was the worse plug #2 The #6 was pretty bad too the otehrs look clean with a slight grey color to them.
I pulled the intake to look in the intake ports for build up.  I can see the build up starting on all of the intake valves at the base of the stem.  I had the heads rebuilt before and this was the issue then.  I think the gap of the plugs is .035.  The coil was in the car when I bought it a few years ago.  It is a Mallory Promaster Classic series.  Any suggestion on what plugs I should run.  I calculate the compression to be close to 10:1.
Here are the specs.
Part Number:
MAA-29440
Coil Wire Attachment:
Male/HEI
Coil Style:
Canister
Primary Resistance:
0.600 ohms
Coil Internal Construction:
Oil-filled
Maximum Voltage:
55,000 V
Turns Ratio:
105:1
Secondary Resistance:
12.3K ohms
Inductance:
7.3 mH
Peak Current:
100 mA
Spark Duration:
500 uS
Mounting Bracket Included:
Yes
Coil Wire Included:
No
Ballast Resistor Included:
Yes
Coil Color:
Black
Coil Shape:
Square
Height (in):
5.297 in.
Length (in):
3.706 in.
Width (in):
3.846 in.
Post #: 8
RE: oil build up on intake valves - 7/8/2008 7:15:35 PM
Gorn
Status: online
Gorn's photo gallery
First off I think Jr72rs is correct. Valve seals is the most likely issue. There are a lot of option out there to try, You can switch to an umbrella type seal.
The only think I could add is some questions, There is no type of EGR valve on this engine? Or a PCV valve? Somthing that could be dumping crap into the intake. How does the car idle is it loading up all the time?
67 RS/SS, 350/4 speed, 12 bolt, Power top, Full gauges
Dingers Build Thread
Post #: 9
RE: oil build up on intake valves - 7/8/2008 7:55:26 PM
69RSSS
Status: offline
I do have a PCV valve, a new one was installed when I head the head rebuilt.  I didn''t build the heads.  I need to find a shop to do this work for me.  The car idles fine.  What do you mean by loading up?
''69 RSSS 350/ Muncie 4 Speed, Houndstooth, Full Factory Gauges.
(in reply to Gorn)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> General >> General Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
