1997 cooling fan problems
Login | |
1997 cooling fan problems - 7/6/2008 7:43:47 PM
dmc_12
relays checked, block sensor changed, thermostat sensor changed, jump voltage directly to the fans they run. what am i missing?
RE: 1997 cooling fan problems - 7/8/2008 3:11:31 AM
knoxville
It typically has four terminals, two of which are current feeds from a fused source of 12-volt electricity. At the relay, there is one current feed into an electromagnetic coil, and one feed into a set of contacts for the switch, which is open. The other terminal for that open switch is connected to the electric motor for the fan. The fourth terminal, also for the coil, is wired to the PCM, which may look at various signals to determine whether or not to provide an electrical ground for that coil. ________________________________________ Autopartswarehouse..ROCKS!\m/
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
