check engine light
Login | |
check engine light - 7/8/2008 12:09:56 PM
b4cmurph
I have a 99 ls1 z28 when i first got the car a month ago i changed the plugs wires fuel filter put a k&n cold air filter on it and changed the oil then went from there. my check engine light is on,i got it read at auto zone and it said failure over 80mph, low volts to knock 1 and 2, 02 sensors bank 1 sensor 1, bank 2 sensor 1 both above converters and it had low fuel pressure. i changed the fuel pump with a ac delco. that did not work so i took it to the dealer to have them read it and see what they thought.they read the computer and said the computer was bad they was for sure that it was bad i told them i did not think that was the problem they changed it and it was not the problem light came back on this time both driver side 02 sensors so i changed them. then it said both passenger 02s then i changed them got it reset came back on again so i got it read again it said both knocks changed them reset the computer again it came back on and said 02''''s bank 1 sensor 1 and bank 1 sensor 2 and low volts to knock 1 and 2 sensors. I dont know what to do. All changes I have done myself but changing the computer
< Message edited by b4cmurph -- 7/9/2008 6:59:43 PM >
RE: check engine light - 7/25/2008 10:55:25 PM
Camaro_Boi69
well im not a genius at electronics in these newer cars but have u took time to see if u have power to the sensors that read bad.? or u might have something grounding out so they read bad
_____________________________
[img] [/img] Stickers give you 20 extra hp no questions asked. as a ricer said.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
