Ignition Issue
Login | |
Ignition Issue - 7/9/2008 7:37:36 PM
RallySport88
Ok, truthfully I have no idea what to call the problem i have... I have a wire that runs under my dash and it looks like it is used to bypass the neutral safety switch (does that sound right?) anyway this wire sometimes gets a little warm and when it does it stops me from being able to crank my Maro... Any Idea''s? Thanks, Cole
RE: Ignition Issue - 7/9/2008 8:59:07 PM
MadMikeZ28
I am assumimng you have an 88??? Is it a late 88? In the 89 Model year was the start of the passkey. You can tell by looking at the ignition key and see if it has a pelet in it near the grip or if it was replaced and bypassed then look at the lock cylinder and is it flat where you put the key in or dished in a little. If its flat then that is the passkey and some one may have bypassed that. But not seeing what you are talking about its near impossible to tell. is the can an automatic? Then the Nuetral safety switch would be under the console on the shifter lever. If its a manual then there would be a switch on the pedal. What color wires? A little more info would help.
_____________________________
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Ignition Issue - 7/15/2008 1:09:27 PM
RallySport88
Sorry it''s tqaking me forever to get back with the Info Mike.. i Had to go out of town so i can''t see the Maro right now, But it''s an Automatic, don''t know what part of 88 it is though...
RE: Ignition Issue - 7/15/2008 3:31:04 PM
MadMikeZ28
Did you look at the ignition lock where the key goes in? You can tell by looking at that if its a passkey or even if the sticker is still on the window.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
