Cooling system issues
Login | |
Cooling system issues - 7/14/2008 4:46:16 PM
superhotchevy
My fans work great, I just replaced the thermostat (installed correctly) the water pump is good, it''''s full of coolant and for some reason it keeps trying to overheat. i have no leaks either but it keeps overheating. I''''m stumped... i need some real advice.
< Message edited by superhotchevy -- 7/14/2008 4:50:29 PM >
_____________________________
my car's a hybrid, it burns gas and rubber!!
RE: Cooling system issues - 7/15/2008 5:03:25 AM
aightball87
check the coolant sensor on the left bank head. (right side if looking at the motor) it is just below the exhaust. if it is reading wrrong it would definately be the problem.
RE: Cooling system issues - 7/16/2008 10:16:06 AM
EnFuegoZ28
Did you bleed the system??
96 Z28, Black, A4, Shift Kit, T-Tops, SLP CAI, Flowchoker Exhaust, cutout, 3.73's, Other Than That Stock, (as far as I know)
RE: Cooling system issues - 7/16/2008 10:41:11 AM
Camaro 69
What year and engine do you have? You first need to determine whether your gauge is telling the truth or not. Has your water pump been replaced shortly before the overheating started, by chance? Older v-belt set-ups used a conventional rotation water pump, serpentine uses reverse rotation. If there was a mix up, it will cause overheating.
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
