I redlined my engine! plz help!
Login | |
I redlined my engine! plz help! - 7/15/2008 12:51:51 PM
ToledoG90
now i know i was stupid for doing this but this is my first car and i didnt really know any better until now!!! i have a v6 camaro and i took it out while it was raining and i started doing donuts. while doing donuts i didnt was flooring the gas and the rpms reached 7. now i have seen this done with a v8 and for some dumb reason i thought my v6 could do the same. i was wrong!!! i didnt blow my engine but something came loose inside the engine and now its making a knocking sound. Im extremely disappointed in myself. i would like to know if anyone might know what went wrong with my engine... i have learned my lesson and i will never do that again. plz help!
RE: I redlined my engine! plz help! - 7/15/2008 8:17:40 PM
Camaro 69
One of the things that gets damaged from over-revving is the valve train. I wouldn''t be surprised if you either bent a push rod, bent a valve, or snapped a rocker arm.
_____________________________
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
RE: I redlined my engine! plz help! - 7/16/2008 8:43:55 AM
z28pete
Just keep in mind that very few stock engines can go to 7000 RPM without hurting themselves. By the way, what does it prove when you do dounuts?
Pete
RE: I redlined my engine! plz help! - 7/16/2008 3:16:10 PM
Gorn
I would have to hear the noise but you most likely streched the rods out of shape. If it is still running and does not have a lot of vibration I doubt you spun a bearing yet. If this is a 3.4 then the bottom is a weak point. I have seen its older sister (the 3.1) strech 5 of the 6 rods due to over rev-ing. Good new is the machine work to get it back running is cheap (rod resizing), bad news its a ton of labor to tear the engine down.
< Message edited by Gorn -- 7/16/2008 3:20:45 PM >
67 RS/SS, 350/4 speed, 12 bolt, Power top, Full gauges Dingers Build Thread
RE: I redlined my engine! plz help! - 7/16/2008 6:02:08 PM
ninetysixyenko
quote:
ORIGINAL: z28pete Just keep in mind that very few stock engines can go to 7000 RPM without hurting themselves. By the way, what does it prove when you do dounuts? very few stock domestic engines. uhh. question.. thought th camaros had rev limitors..? i know my 96 did.
DC-Sport Header Back Exhaust, Injen SRI, AEM Under Drive Pulleys, B&M Short-Throw, Big Brake Kit, Torque Dampener. 5% Tint All Around, Halo''''s
RE: I redlined my engine! plz help! - 7/16/2008 7:30:57 PM
z28rob
my 95 has a rev limiter hit that once or twice
95 z28 lt1 6 speed 13.1@106 eibach drag launch springs, kyb agx, slp headers/y pipe, hooker cat back no cat wit cut out, msd plug wires, moroso cai, holley throttle body, and alot to come
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
