Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Project: killeRS
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> RE: Project: killeRS Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: Project: killeRS - 7/17/2008 12:08:40 PM
MadMikeZ28
Status: offline
I like serpintine. But even the V belts used accesory holes on the heads unless it was real early.
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to brassknukl)
Post #: 11
RE: Project: killeRS - 7/17/2008 9:01:41 PM
brassknukl
Status: offline
any danger in getting them tapped out
my fiances ****father has a machine shop
Project: http://www.camaroforums.com/m_226016/tm.htm
(in reply to MadMikeZ28)
Post #: 12
RE: Project: killeRS - 7/17/2008 10:22:43 PM
MadMikeZ28
Status: offline
There is no casting material there to make all the holes. You can look at the heads in your car now and see the extra material that is machined flat.
Post #: 13
RE: Project: killeRS - 7/18/2008 1:47:57 PM
brassknukl
Status: offline
my 305 looks the same way the front of the heads are flat with holes drilled in them
Post #: 14
RE: Project: killeRS - 7/18/2008 1:59:15 PM
Camaro 69
Status: online
From what I understand, you could drill out the heads, but you might have to shim out your mounting points since the heads don''t have the raised mounting bosses. I would check with an engine machine shop first to see what you can get away with.
< Message edited by Camaro 69 -- 7/18/2008 2:02:05 PM >
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
Post #: 15
RE: Project: killeRS - 7/18/2008 2:14:10 PM
Camaro 69
Status: online
And from the lack of mounting holes, I''m gonna say those heads are pre-1968 vintage. When you have the valve covers off, take down the casting #''s and look them up.
(in reply to Camaro 69)
Post #: 16
RE: Project: killeRS - 7/21/2008 8:18:40 AM
brassknukl
Status: offline
figured it out
found a bracket on summit that bolts to the block and should clear my gear box
same for the alternator bolts to block on pass side.
after some research (and a few trips to autozone) i found out its actually from a 1970 impala
short water pump (yessss!) everything "should" line up now.
picked up a new waterpump PS pump and oil pump w/screen for around $100
now for painting...
im thinking a gloss black.
Post #: 17
RE: Project: killeRS - 7/21/2008 8:51:42 AM
brassknukl
Status: offline
can anyone tell me which direction the pulleys need to spin.
im assuming the crank goes clockwise?
also whats with the 2 pipes for coolant on the manifold the pump only has one.
on the 305 the pipe on the pump is plugged?
Post #: 18
RE: Project: killeRS - 7/21/2008 11:59:49 AM
MadMikeZ28
Status: offline
one pipe goes to the water pump and the pipe to the side goes to the heater core
Post #: 19
RE: Project: killeRS - 7/21/2008 1:28:02 PM
brassknukl
Status: offline
thanks for all the help guys
just waiting on some shipping now
Post #: 20
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 3rd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
