RE: Project: killeRS
Login | |
RE: Project: killeRS - 7/24/2008 10:19:21 AM
brassknukl
it ran with the cam in it and pump gas just fine before. why would it be any different now?
_____________________________
Project: http://www.camaroforums.com/m_226016/tm.htm
RE: Project: killeRS - 7/24/2008 10:42:53 AM
Camaro 69
quote:
ORIGINAL: brassknukl 8890462 also says h136 then h106 on the other and gm13 on both Are you sure it''s not 3890462? Can''t find any such animal as 8890462. 3890462 are either 1966-67 327/350, 1.94 intake, 1.5 exhaust, 63 cc chamber or 1966-67 302/327, 2.02 intake, 1.6 exhaust, 63 cc chamber h136 and h106 are the cast date, Months are stamped from A-L (January-December) h=August, 10 & 13 is day of the month, 6=year, 1966 That would explain your lack of mounting holes, since they are pre-1968 heads as I earlier stated they might be. Those heads are a small chamber, you''ll definitely need to burn premium gas. http://www.chevy-camaro.com/chevy-camaro-chevy-head-codes.asp?group=1
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
RE: Project: killeRS - 7/24/2008 11:31:01 AM
MadMikeZ28
quote:
ORIGINAL: brassknukl it ran with the cam in it and pump gas just fine before. why would it be any different now? You sure it ran fine? Test drive? Heared it? Hear say? To its full potential? My in-law bought a "good running" sb from mexicans. well they thought a cam with rounded lobes and dished lifters was a good runner.
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Project: killeRS - 7/24/2008 11:37:21 AM
MadMikeZ28
It would not hurt to check with your machine shop connection for a set of heads with bigger chambers and accessori holes. It might cost you some cash with a trade for those heads. They may even be able to give the straight popp on how "sought after" they really are.
RE: Project: killeRS - 7/25/2008 8:35:16 AM
brassknukl
by pump gas do you mean 87 or are you telling me i need racing fuel? this was a street engine originally im really leaning toward just getting it in the car and starting it first.
RE: Project: killeRS - 7/25/2008 8:38:47 AM
brassknukl
if after its in the car it needs the heads changed then ill do it. i just want to see how it runs before i start changing things. now im getting nervous about clearing the gear box in that 3rd gen. initial measurements are kinda close. but ill have a short water pump so i think itll just make it. i hope
< Message edited by brassknukl -- 7/25/2008 8:40:14 AM >
RE: Project: killeRS - 7/25/2008 8:44:17 AM
brassknukl
quote:
ORIGINAL: Camaro 69 Are you sure it''''s not 3890462? Can''''t find any such animal as 8890462. sorry its a 3 youre right
RE: Project: killeRS - 7/26/2008 2:06:16 PM
brassknukl
got water and PS pumps attached waiting for alternator
< Message edited by brassknukl -- 7/26/2008 2:07:42 PM >
RE: Project: killeRS - 7/26/2008 5:37:36 PM
350rs
Joined: 4/23/2006 From: St. Louis, Missouri Status: offline
quote:
ORIGINAL: Camaro 69 quote:
ORIGINAL: brassknukl 8890462 also says h136 then h106 on the other and gm13 on both Are you sure it''''s not 3890462? Can''''t find any such animal as 8890462. 3890462 are either 1966-67 327/350, 1.94 intake, 1.5 exhaust, 63 cc chamber or 1966-67 302/327, 2.02 intake, 1.6 exhaust, 63 cc chamber h136 and h106 are the cast date, Months are stamped from A-L (January-December) h=August, 10 & 13 is day of the month, 6=year, 1966 That would explain your lack of mounting holes, since they are pre-1968 heads as I earlier stated they might be. Those heads are a small chamber, you''''ll definitely need to burn premium gas. http://www.chevy-camaro.com/chevy-camaro-chevy-head-codes.asp?group=1 i dont mean to bump in and steal a thread, but i got a quick question. i have heads on my car that i cannot for the life of me fine a CC for. the numbers are 14102193. i know the intake and exhaust valve sizes, but i cannot find a CC rateing for them ANYWHERE. I wanna know so i can get a more accurate combustion ratio for my engine when its rebuilt. PM me or something if ya could. thanks.
March 2008 Ride of the Month 89 RS, 60 over 350 crate, 5 speed.
RE: Project: killeRS - 7/26/2008 9:06:56 PM
Camaro 69
OK, I''ll try and put this here real quick before anyone notices! Here''s what I found: 65.3 c.c. combustion chamber 1.94" intake 1.50" exhaust valves "This cylinder head is not a performance oriented head. It is classified as a high swirl head that was intended for good bottom end torque and fuel economy. The intake runner is restrictive because it has a ramp cast into the bottom of the bowl to promote high swirl."
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
