Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Timing question
  Printable Version
Camaro >> Brand Review >> Engine & Internal >> Timing question Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Timing question - 7/19/2008 12:52:56 PM
kyphur
Status: offline
kyphur's photo gallery
So I borrowed a friend''s timing light and was about to go to set the timing when another friend of mine told me that I would probably get a reading that isn''t right due to the different parts I have on there over stock.  Granted the engine is running a good bit higher cam, roller rockers, etc, etc. but it still relies on spark and distributor to determine firing.  So a timing light should work no matter what, right?
< Message edited by kyphur -- 7/19/2008 12:53:13 PM >
_____________________________
kyph
http://www.kyphurland.com
1974 Type LT Z28
Rebuilt 350ci L82 and th400 trans
All matching numbers
Camaro 69 is always right, trying to correct him is always just a misunderstanding on your part.
Post #: 1
RE: Timing question - 7/19/2008 12:56:58 PM
SpecterGT260
Black Stig FTW
Status: offline
SpecterGT260's photo gallery
the timing light shows you exactly when the engine if firing so yes
quote:
ORIGINAL: BigNic
if she offers to shift for you its on.....
http://www.camaroforums.com/m_109346/mpage_1/key_/tm.htm#
(in reply to kyphur)
Post #: 2
RE: Timing question - 7/19/2008 2:25:57 PM
Camaro 69
Status: online
The timing light will still work like it should. But with your modifications, your engine is most likely going to want to be at a different setting from stock specs.
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
Post #: 3
RE: Timing question - 7/19/2008 2:29:50 PM
Camaro 69
Status: online
You want max advance under a load before the engine pings (marbles). If you have an automatic trans, the hot-rodders way of timing doesn''t even require a light.
(in reply to Camaro 69)
Post #: 4
RE: Timing question - 7/19/2008 2:30:38 PM
kyphur
Status: offline
SpecterGT260>  Yeah, that''s what I thought but the guy telling me this is fairly intelligent about building cars, boats, etc. so it made me doubt it a little.  I''m not tech or mechanic so I''ll listen to someone that has more experience than me but when I have doubts I''ll ask around and get a general consensus.
Camaro69>  Yeah, I was thinking maybe an advance somewhere around 12.
kyph
1974 Type LT Z28
Post #: 5
RE: Timing question - 7/19/2008 2:31:37 PM
Camaro 69
Status: online
With the car in gear, stand on the brakes and give it the gas, but not so much to move the car or break the tires free.
Post #: 6
RE: Timing question - 7/19/2008 2:32:51 PM
Camaro 69
Status: online
Have a helper advance the timing until the engine pings, then back it off until the ping stops.
Post #: 7
RE: Timing question - 7/19/2008 2:33:28 PM
kyphur
Status: offline
Camaro69>  Yeah, that''s the way we did it since it''s a TH400.  Raise piston 1 till it''s at its height and then set the distributor from there and move the distributor clockwise to advance it till it''s all good.  I''m pretty sure I''m really close but when I shut down on the third run today it dieseled one time after shutdown.  It''s temp was running only 160 with the new Griffin radiator so I know it wasn''t hot but maybe the spark plugs were still hot or something.
kyph
1974 Type LT Z28
Post #: 8
RE: Timing question - 7/19/2008 2:35:41 PM
kyphur
Status: offline
Camaro69>  Ha ha, I live out in the middle of nowhere so getting a helper to help me sometimes requires a lot of bribing with beer.
kyph
1974 Type LT Z28
Post #: 9
RE: Timing question - 7/19/2008 2:36:55 PM
Camaro 69
Status: online
Oops! Maybe that''s why it dieseled? The distributor shaft rotates clockwise. Rotating the body Counter-Clockwise advances the timing.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forum >> Brand Review >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284182
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
