Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
electrical problem?
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> electrical problem? Page: [1]
Login
Message << Older Topic   Newer Topic >>
electrical problem? - 8/16/2008 8:25:27 PM
franklin01
Status: offline
hi, i recently got a 1983 camaro which has some issues which i think are electrical. it started when the fusable link going to the starter blew. now every time i replace the fusable link and go to hook up the battery again, as soon as i touch the negative lead to the battery the fusable link blows and sends up smoke. does anyone know what might keep causing this? i have had the starter checked, as well as checked the wire as much as possible for shorts, and ive also checked the ground going from the negative battery lead to the frame.
Post #: 1
RE: electrical problem? - 8/16/2008 9:00:28 PM
MadMikeZ28
Status: online
The fuseable link is just that, A fuse. Depending on which link is blowing depends on what it may be. What does not work when that link is blown? Headlights, power when ignition on, etc?????
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to franklin01)
Post #: 2
RE: electrical problem? - 8/16/2008 11:01:23 PM
franklin01
Status: offline
the headlights do come on, noting in the interior comes on (radio, dash lights, etc), and obviously the starter doesnt come on, so im guessing it goes to the ignition...so could this be a short in the ingnition?
< Message edited by franklin01 -- 8/16/2008 11:02:38 PM >
Post #: 3
RE: electrical problem? - 8/16/2008 11:47:59 PM
MadMikeZ28
Status: online
Do you have two links on the starter? do you have the V6, V8 or L4? Could be an internal short in the alternater, blower relay or motor. But since you have no interior lights but the head lights work that may be another situation. The link for the headlight switch also sends power to the fuse box for the tail light, stop, and courtsy fuse (interiror lights, hatch release, cigar lighter, horn) on V6 and V8 models.
The other link goes to the charging system and the circuit breaker on the fuse panel that is for defoger, power seats, windows, locks and the ignition switch. Search through the power wires on those systems and look for a break or insulation rubbed through. See if you can have the alt tested for a short of some kind.
Post #: 4
RE: electrical problem? - 8/17/2008 12:06:42 AM
franklin01
Status: offline
yeah there is two links on the starter and its a v6 2.8L
(in reply to MadMikeZ28)
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 3rd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604223
madmikez284186
95slvrz283155
02stangt3009
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
