Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
LT1 rough idle, ticking, poping in exhaust
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V8 Tech >> LT1 Camaro >> LT1 rough idle, ticking, poping in exhaust Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
LT1 rough idle, ticking, poping in exhaust - 9/7/2008 10:32:41 PM
evilbeef54
Status: offline
I just had the headers and cut out put on, everything was running great, took it to the track last night made a few passes ran great. This morning everything was running great. However tonight when i started it up it idled real rough, the tach was bouncing between 850 and 500 rpm, when driving it slow a few times it feels like it misses and a few times there was a soft poping from the exhaust. Also with the engine idleign and the hood open there is a soft ticking sounds from the back of the drivers side valve cover. Once the car warmed up the missing, rough idle, and poping at slow speed seemed to go away. Could this be a valve adjustment problem? The other thing is i removed the intake, MAF, and intake elbow several times while i was trying to install an ignition and airflow controller (this plugs into the MAF) for the nitrous, however i did not run the nitrous last night and the controller is not hooked up right now. What do ya''ll think valve adjustment, MAF issue, or something else?
_____________________________
1972 Camaro 350 Mild RV cam M22 Performer N20 100 wet MSD dig6plus MSD Pro Billet dizzy MSD Blaster SS coil
1994 Camaro Z28 350 Small 50 shot dry N2O eaton posi eaton axles richmond 4:10 K&N intake MSD opti MSD6al HSW interface
Post #: 1
RE: LT1 rough idle, ticking, poping in exhaust - 9/8/2008 9:48:01 AM
z28pete
Status: offline
z28pete's photo gallery
Your plug wires may have gotten roasted by your new headers, a very common problems if the wires are not routed properly and protected from the heat. The ticking is probably cased by a plug wire arching to ground, causing misfires, rough running, and popping in the exhaust. Although the LT1 is notorious exhaust pops, especially when closing the throttle too fast.
Pete
(in reply to evilbeef54)
Post #: 2
RE: LT1 rough idle, ticking, poping in exhaust - 9/8/2008 12:25:13 PM
evilbeef54
Status: offline
that makes sense, it does kinda feel like that, i''m out of town for work right now, but i''ll check when i get home, thanks
(in reply to z28pete)
Post #: 3
RE: LT1 rough idle, ticking, poping in exhaust - 9/8/2008 5:58:12 PM
ZFITZME
Status: offline
i seem to have the ticking also, would you suggest to change the plugs?
Post #: 4
RE: LT1 rough idle, ticking, poping in exhaust - 9/9/2008 12:00:28 AM
evilbeef54
Status: offline
after thinking about it, this seems similar to when i had a burnt plug wire in my 72 camaro, and the fact that it is intermitent leads me to believe that this may be the case, i''ll investigate when i get home, and ZFITZME, check your plug wires for damage
(in reply to ZFITZME)
Post #: 5
RE: LT1 rough idle, ticking, poping in exhaust - 9/9/2008 5:21:56 PM
acdc6868
Status: offline
I have a similar problem.  It doesn''t idle rough, really, at least I don''t think, but under load when I try to lightly accelerate from about 40 to 50 or 55 it struggles real bad and the exhaust pops a few times (number varies on how hard I''m trying to accelerate).  But, if I push it to the point where it forces it to kick down a gear, its fine and runs great and real strong.  This problem only seems to happen in near 2,000 rpm when trying to accelerate under load.  Any ideas?
Post #: 6
RE: LT1 rough idle, ticking, poping in exhaust - 9/9/2008 10:24:17 PM
noz
Status: offline
thats right buddy it might be one of your spark plug wires if this is the problem you can actiolly  see  a lil blue spark at night
Post #: 7
RE: LT1 rough idle, ticking, poping in exhaust - 9/13/2008 10:48:23 PM
evilbeef54
Status: offline
problem fixed, plug wires on headers thanks everyone
(in reply to noz)
Post #: 8
RE: LT1 rough idle, ticking, poping in exhaust - 9/26/2008 11:02:36 AM
green goblin
Status: offline
I have a similar problem on a 96 z28.I had some headers installed and a few days later I noticed the rpm idle dropped from normal 900 rpm to about 500. Every time I step on the accelerator it bogs, feels like its missing all the way to 2000 rpm, after that the car runs fine. Both cats are off but the o2 censors are still on. Can anyone help with this issue? Thanx
Post #: 9
RE: LT1 rough idle, ticking, poping in exhaust - 9/27/2008 6:28:37 PM
z28joeyg9
Status: offline
what could of happened is that.. the headers bottomed out... (headers lay so low to the ground) which made it so that the exaust pipes develped an exsust leak.. thats why i never ever perfer heders on a car
- - joey g
(in reply to green goblin)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 4th Generation >> V8 Tech >> LT1 Camaro
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
