Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Harmonic Balancer removal problem
  Printable Version
Camaro Forum >> Camaro Models >> 2nd Generation >> Harmonic Balancer removal problem Page: [1]
Login
Message << Older Topic   Newer Topic >>
Harmonic Balancer removal problem - 9/12/2008 5:27:17 AM
1977 402
Status: offline
My son has a 77 that has a 402 BB, he has puled the engine out since he wants to rebuild it.. We are at the stage of removing the Harmonic Balancer and the bolt has been removed from the balancer to the crank and has attached the balancer puller, it has moved about 1/2 an inch but has stopped, what are we doing wrong or are they all hard to come off?
Post #: 1
RE: Harmonic Balancer removal problem - 9/12/2008 7:11:37 AM
thebandit110
Status: offline
thebandit110's photo gallery
sometimes those balancers can be a real pain. douse it with pb blaster and than use the puller again, make sure your bolts that run through the puller and thread in to the balancer are snug and nothing is getting hung up. especially if the engine was seized it can get real stuck. try the blaster. i swear by it
_____________________________
(in reply to 1977 402)
Post #: 2
RE: Harmonic Balancer removal problem - 9/12/2008 12:11:14 PM
screamineagle
Status: offline
The pb blaster does work great. I would say also spray that on and maybe even crank the balancer back in and spray more let it soak and then pull it should come off. They are a pain sometimes.
(in reply to thebandit110)
Post #: 3
RE: Harmonic Balancer removal problem - 9/12/2008 12:45:40 PM
tammy
Status: offline
Make sure the puller is seated right at the crank and not bottoming out at the puller; Use impact wrench on puller, should come off no problem.
(in reply to screamineagle)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 2nd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604597
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
