''95 LTI engine question
Login | |
''95 LTI engine question - 9/14/2008 6:33:44 PM
jordanrinek
Hello, I am working on a 1995 Camaro LT1. It is a Special Purpose Optioned Camaro that was used for law enforcement. This was my father''s work vehicle. After he retired, they retired his car and he bought it from the auction for me. Recently, the car began overheating, uncontrollably, and also began to miss. After several incidents we decided to start searching by disassembling. So far we have it disassembled down to, and including the water pump. The water pump doesn''t seem right. We also suspect the cooling fans are not functioning correctly. We have decided to replace the Optispark, waterpump, cooling fans, and to have the radiator serviced (or should we replace). We can''t decide whether to change the timing chain, gears and damper because we aren''t real excited over removing the oil pan. I''d really appreciate any advice or suggestions on what we should do. Also, if anyone has any advice on replacement part brands, we would really appreciate it. Tomorrow my Dad is going to take of the harmonic balancer and hub, for the optispark replacement, but we are going to wait to hear from camaroforums before doing the timing chain. The car has 134,000 miles. Before the heating issue it was running fine. I don''t plan to race the car, but I do love high performance. Thanks for helping, we''ll look forward to responses.
RE: ''''''''95 LTI engine question - 9/14/2008 9:06:31 PM
jordanrinek
Thanks Whammer. Very much appreciate the quick response. My Dad said on his older chev v8 he is not sure that he had to drop the oil pan to get the timing cover off. He has an old engine. Is it possible to remove the timing cover without dropping the oil pan? It seems dropping the oil pan is pretty intensive. Thanks again for responding.
RE: ''''''''''''''''''''''''''''''''95 LTI engine question - 9/15/2008 4:27:38 PM
luvmysccamaro
This isn''t the right Camaro but you should have this. When we first bought our Camaro, it would overheat real quick and just got the part for like $20 or something. It''s the plastic wing thing on the right.
_____________________________
95 Camaro z28, Paxton supercharged with a 5 PSI pulley, 5.7 V8 LT1, 6 speed manual , Edelbrock headers, MagnaFlow exhaust, etc. I didn''''t install these mods. This is not my car, it''''s my dads (for now ;) .
RE: '''''''''''''''''''''''''''''''''''''''''''''''''''... - 9/16/2008 7:40:56 PM
jordanrinek
Thanks for the responses. We have everything out now, including the harmonic balancer and hub. Water pump seems to turn abnormally. I think the water pump is at least part of the problem. Before we started taking things apart, we changed coolant, thermostat, flushed out radiator. We have the air dam that diverts air to the radiator. The car had 134k miles and it is time to provide some care. There seems to be a lot of oil around the timing cover. Maybe the timing cover is leaking oil onto the ignition? We plan to follow everyone''s advice and do the timing chain, gears, dampener. This site is unbelievably great. Someone had posted a trick to getting the harmonic balancer hub off. It worked great. Does the oil pan have to be removed to take off the timing cover. I think the timing cover is leaking and that is at least part of the problem. Please please tell me I don''t have to drop the oil pan. The oil pan seems to be a really big job. Does anyone have any suggestions on which brand timing chain to get? Which is the best optispart? Who makes the best water pump. Any suggestions for replacement cooling fan. Thanks for all the help!
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
