Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
lt1 swap into an ls1 based car
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V8 Tech >> LT1 Camaro >> lt1 swap into an ls1 based car Page: [1]
Login
Message << Older Topic   Newer Topic >>
lt1 swap into an ls1 based car - 9/16/2008 6:47:50 PM
seegeer
Status: offline
i recently picked up a 99 camaro, it doesnt have an engine or trans, and half an engine harness for 1000 bucks, the car is black with ttops and very straight body,  i have an engine and trans out of a 96 camaro, can i use that engine in the car, i have the complete wire harness from cpu to fuse box ect,,i guess my real question is can i use any of the stock ls1 harness
thanks
Post #: 1
RE: lt1 swap into an ls1 based car - 9/16/2008 7:41:40 PM
JD1969
Status: offline
JD1969's photo gallery
You will need to switch out the harness, it''s not that hard.
_____________________________
2001 SS A4
11.500 @ 116.01
SLP Lid/Granitelli Maf/Fernco/JD1969 custom cat back/UMI Lower Control Arms and PHR/Flowtechs/TSP Cam/Yank 4000 stall
(in reply to seegeer)
Post #: 2
RE: lt1 swap into an ls1 based car - 9/17/2008 9:17:39 AM
bidicamaro
Status: offline
bidicamaro's photo gallery
Isn''t this a little different? Don''t most people put the LS1 in the LT1 based cars? Oh well. I get why you''re doing it though. I have also been "notified" that the harness has to be swapped.
94 Z28, Moroso CAI, Edlebrock headers, 3" pipe, cam, MSD and the t-56. She's fast...
(in reply to JD1969)
Post #: 3
RE: lt1 swap into an ls1 based car - 9/17/2008 7:22:08 PM
seegeer
Status: offline
how much of the harness, do i need to go under the dash as well, what all do i keep from the ls1 harness for lights and such,
(in reply to bidicamaro)
Post #: 4
RE: lt1 swap into an ls1 based car - 9/22/2008 9:45:32 AM
bidicamaro
Status: offline
I belive all the lights and blinkers and horn and such are just in the fuse block so I don''t think any of that needs to be changed. I belive it''s just the main harness and ECU that has to be changed.
Post #: 5
RE: lt1 swap into an ls1 based car - 9/22/2008 10:51:53 AM
JD1969
Status: offline
Yea it should only be the engine harness that you need
2001 SS A4
11.500 @ 116.01
Post #: 6
RE: lt1 swap into an ls1 based car - 9/22/2008 11:00:19 AM
importmd
Status: offline
importmd's photo gallery
the front chassis harness is part of the pcm harness, so you will need to swap out all the wiring under the hood and under the dash
08 HD 1200N
01 Tahoe LT
95 Z28 T56
78 CJ 5 Trail Rig
http://www.msnusers.com/newcamaro/shoebox.msnw
Post #: 7
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 4th Generation >> V8 Tech >> LT1 Camaro
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5573
spectergt2604213
madmikez284178
95slvrz283155
02stangt2995
74454bb2749
cplthomas2551
bluovlh8er2469
blade2300
spartan662255
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
