Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
305 v8, 4 barrel carb problem HELP
  Printable Version
Camaro >> Brand Review >> Engine & Internal >> 305 v8, 4 barrel carb problem HELP Page: [1]
Login
Message << Older Topic   Newer Topic >>
305 v8, 4 barrel carb problem HELP - 9/17/2008 10:23:42 PM
c4maro
Status: online
hey, im only 15 and i am still really learning about cars. i have an 87 z28 with a pretty much stock 305. when i fire the car up it idles really high at about 2000 or more rpm for a long time and then i have to slam the throttle to bring it down, it takes alot of slams to get it to normal idle. i only usually take it out of the garage and let it idle for like 2 mins and it idels ok after i have it at the good idle speed. but the guy i got it from said when he took the car out for about an hour drive it would end up stalling. i dident really worry about that and it went out of my mind for the 2 months ive had it now. so a couple days ago i gotta day liscence on it to take it to get the stereo put in, and after about 20 minz of driving, when we hit a stop light it would just barely stay alive and would juuuust about stall so my dad would have to put it in neutral and just keep reving it when we were stoped. and i couldent see it idleing at all after about an hour of drivving. then my uncle came over who knows a bit more about cars and he played around with the carb(carter afb competition series 4barrel). There was this little mechanism on the left side of the carb with a spring attached, he would fool around with and it only moved about 1 cm back and forth, he said it was part  of the choke. and when he moved it around it would idel normally then go back to just about stalling. so if any1 took the time to read this and they have any idea whats wrong, or what i need to do, then please reply, thanks ( and by the way, when my uncle was fooling around with the carb, that was after i had driven it for 20 minz, therfore the problem was present)
THANKS.
Post #: 1
RE: 305 v8, 4 barrel carb problem HELP - 9/18/2008 4:23:09 PM
Camaro 69
Status: offline
Check your other post for the response. To avoid confusion, one post per question is all you need to put out here.
_____________________________
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
(in reply to c4maro)
Post #: 2
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Brand Review >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
