Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
What parts to get?
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> What parts to get? Page: [1]
Login
Message << Older Topic   Newer Topic >>
What parts to get? - 9/18/2008 3:00:13 PM
joker905
Score: 0
Status: offline
I have a 98 z28, do I need to buy an install kit with my Richmond ring and pinion?
Post #: 1
RE: What parts to get? - 9/18/2008 4:10:15 PM
Camaro 69
Score: 0
Status: online
Yes you do. What''s usually included is the following:
Ring gear bolts & washers, crush sleeve, pinion carrier bearings, pinion nut & washer, pinion seal, marking compound & brush, thread locking compound, silicone sealer, pinion & carrier shims, cover Gasket. You DO NOT want to reuse any of those old parts, some for obvious reasons. The one thing you could do without is the cover gasket. I only use the silicone gasket goop and forget about fighting with the gasket, it won''t leak.I have to ask though, since you asked that question, do you have the knowledge and proper tools to set-up the gears correctly? If you don''t set them up properly with the correct mesh and backlash, you''ll end up eating the gears sooner than later.
_____________________________
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
(in reply to joker905)
Post #: 2
RE: What parts to get? - 9/18/2008 11:40:47 PM
joker905
Score: 0
Status: offline
I''m going to take it to a mechanic.
(in reply to Camaro 69)
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forum >> Camaro Models >> 4th Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
