Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
I think my clutch is going out?
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> I think my clutch is going out? Page: [1]
Login
Message << Older Topic   Newer Topic >>
I think my clutch is going out? - 9/23/2008 8:11:05 AM
GoofieJ21
Score: 0
Status: offline
Recently when I first start driving my clutch seems to have no back pressure when releasing, as in when I release the peddle it doesn''t come all the way back to the starting point, instead it says about half way pressed to where it''s right after the contact point. Also the contact point is much closer (about 3 inches) to the floor than usual. Eventually after the car warms up after about 20 min and after I pump the clutch a few times it goes somewhat back to normal with the clutch going back to starting point but very little pressure to do so. I''ve had a clutch go out on me before but it happened all at once. My camaro does have almost 100k miles on that clutch, is this the normal life of a clutch? I do not drive my camaro hard at all. I''ve never red lined it and have never had trouble with the clutch up to this point. Is this a sign that my clutch is gradually going out? Thanks for the help guys.
_____________________________
1999 3.8L V6 5 spd
Tint
K&N Stock Air Filter
Magnaflow cat back exhaust system
Cooper Zeon Tires on Eagle Alloy rims
Alpine Deck w/
Ipod connection
Bluetooth Phone Enabled
Infinity Speakers
Infinity Basslink 200W Amp & 1-10" Sub Combo
Post #: 1
RE: I think my clutch is going out? - 9/23/2008 8:23:12 AM
Nessy
Score: 0
Status: offline
Sounds like it may be an air problem.
Did you ever replace the release bearing, clutch plate, or clutch disc?
Try bleeding the clutch.
Sometimes you can crack the bleeder at the slave cylinder, open the cap on the master cylinder and inject brake fluid into the slave cylinder and it will push air out the top of master cylinder. I''m not to familiar with it myself, id look for more detailed guides and assistance.
(in reply to GoofieJ21)
Post #: 2
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 4th Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
