Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
9 bolt rebuild
  Printable Version
Camaro Forums >> Camaro Models >> 3rd Generation >> 9 bolt rebuild Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
9 bolt rebuild - 9/24/2008 9:10:27 PM
350rs
Status: offline
350rs's photo gallery
anybody know a good site to get a rebuild kit for the 9 bolt? if not it looks darn good as is, but i was gona go 3:72 or 70 or whatever messed up ratio this thing has. but i finally got the old rotors off. took almost a half a can of pb blaster and a 12 freggin pound sledge. but i got them off. lol the bolts holding the mounting bracket are soaking now. ill try and pull them off tomorrow and clean them up too. can i flip that one side 180 to make it face the rear without any problems? and obvioulsy install the calipers off a 89 instead. btw... hows the parking brake work on the 89 over a 88? still use the actual caliper or is it inside the rotor kinda like a drum?
_____________________________
March 2008 Ride of the Month
89 RS, 60 over 350 crate, 5 speed.
Post #: 1
RE: 9 bolt rebuild - 9/25/2008 6:18:16 AM
blackz87
Status: online
1) For parts try Randy''s Gear & Pinion.
2) 11.655 rotors will require different backing plates.  (not the same as the 10.5).
3) Gear change to 3:70/3:73 is in question untill you state which series carrier you have now. Those gears require 3-series carrier. Present ratio needs to be 3:27/3:45. Check the stamping on the ring gear. A 2:77 ratio means you are SOL for gear change.
4) Parking brake cables are also different and difficult to find. Also I can not recall the set up for the parking brake but it is different.
87 Black IROC-Z28
350 Crate with TPI
original owner
(in reply to 350rs)
Post #: 2
RE: 9 bolt rebuild - 9/25/2008 9:01:07 AM
350rs
Status: offline
yea its a 3:27 ratio. i found that awhile back. i thought i had posted a pic in a different thread but ill do it again here. i may be able to get the parts needed through work if i dig enough. but if its to much im just going to replace the seals and put new fluids in and put it back in my car.i will be redoing the brake lines. i think i found the emergancy brake cable at my work for the car, but ill have to look again. its gona be a PITA to get those brakes it working it sounds like. i may just stick with the 88 setup for awhile then go with a really nice bear setup i can get through work fairly cheap ( from what it originally cost)
Thumbnail Image
Thumbnail Image
Attachment (2)
(in reply to blackz87)
Post #: 3
RE: 9 bolt rebuild - 9/25/2008 9:36:13 AM
blackz87
Status: online
I would stick with the 3:27 ratio and forget about the gear change.  My opinion, it is a good ratio for city/highway/performance.
87 Black IROC-Z28
350 Crate with TPI
original owner
(in reply to 350rs)
Post #: 4
RE: 9 bolt rebuild - 9/25/2008 9:55:26 AM
350rs
Status: offline
yea that was my thought to. for now i might just leave it since its such a PITA to get that done for these things. years down the road if i still have it i may go to a 12 bolt or something. btw, are these axels held in with c clips or are they a retainer like a 9"?
Post #: 5
RE: 9 bolt rebuild - 9/25/2008 10:11:30 AM
blackz87
Status: online
Axle shafts are held in by retainers, no "C" clips on any 9-bolt.
87 Black IROC-Z28
350 Crate with TPI
original owner
(in reply to 350rs)
Post #: 6
RE: 9 bolt rebuild - 9/25/2008 10:37:08 AM
MadMikeZ28
Status: offline
Gear changes have not been limited to what carrier you have for a long time.
http://store.summitracing.com/egnsearch.asp?N=700+4294918962+4294901310+115+4294790781
If you go down the list you will find some where there are 2 sets of 3:73. One for numericaly higher and the other for lower number carriers.
(I choice 3:73 to lower the number of sets in my search)
Post #: 7
RE: 9 bolt rebuild - 9/25/2008 12:30:03 PM
350rs
Status: offline
quote:
ORIGINAL: blackz87
i thought i had read that somewhere, but its good to have someone else confirm it for me.
as for the gears. it may come down to cost. id LIKE to go with 3:73, but i do think that the 3:27 is a good mix between driveablility and performance.
i pulled the old rear out today. i tell you what, those brake cables are a pita.
Post #: 8
RE: 9 bolt rebuild - 9/25/2008 2:14:14 PM
blackz87
Status: online
quote:
ORIGINAL: MadMikeZ28
I guess you don''t know that 9-bolt & 10-bolt parts are not interchangeable.  Also if you would read the Summit ad, it is for 7.500/7.625 dia 10-bolt gears for the 2&3 series carriers. No where is mention of thicker 7.750 dia 9-bolt gear in the 3:73 ratios.
87 Black IROC-Z28
350 Crate with TPI
original owner
(in reply to MadMikeZ28)
Post #: 9
RE: 9 bolt rebuild - 9/25/2008 4:21:06 PM
MadMikeZ28
Status: offline
quote:
ORIGINAL: blackz87
I guess you don''''t know that 9-bolt & 10-bolt parts are not interchangeable.  Also if you would read the Summit ad, it is for 7.500/7.625 dia 10-bolt gears for the 2&3 series carriers. No where is mention of thicker 7.750 dia 9-bolt gear in the 3:73 ratios.
Well you caught me on that goof.
But I guess what you don''t know is that unless he were to have a 2.77, all gears from a 2.92 to 4.11 will fit since it will aready have a 3 carrier. I looked this up before with the help of a guy that is a rear end specialist. I had to call him for the name of the site again (9bolt.com, how could I forget that).
So if he were to start with the next lowest in a Camaro, 3.08, (not 3.27 as you stated) he could go up to any gear.
But I forgot. Because you black87, have not seen it, it does not exist.
http://www.9bolt.com/gearsets.html
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 3rd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
