Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Fuseable Link?
  Printable Version
Camaro Forums >> Camaro Models >> 3rd Generation >> Fuseable Link? Page: [1]
Login
Message << Older Topic   Newer Topic >>
Fuseable Link? - 9/25/2008 4:34:35 PM
hurley870
Status: offline
hurley870's photo gallery
Hey it''s been like a year since ive been on here.  My Camaro has been out of commision all summer.  Finally get it running, new steering column, brakes, springs, etc.  Took it for a test drive after installing the steering column.  About 5 minuts into the drive my tach starts getting jumpy.  At the next light I go and when i shift into 2nd gear there was a loud pop (sounded like exhaust backfire).  A little smoke came from the engine bay around the power brakes booster on the drivers side.  Car is dead, electric and all.  Guy who towed it said may be a fuseable link.  How would I be able to tell whats wrong and how hard is it to replace a fuseable link?  Any help appreciated.
Thanks, Bill
_____________________________
-1988 Camaro Sport Coupe
-5.0 305
-5 speed manual
-Dynomax Catback w/Hi-flow cat
-T-Tops
Post #: 1
RE: Fuseable Link? - 9/25/2008 5:43:53 PM
MadMikeZ28
Status: offline
Well I think the only place the links are located are by the battery and starter. All the fusalbe link is, a wire that will melt away ( a fuse) and a butt splicer to normal wire. When you check them if they look good give a little tug on them. Some times they will burn or corode on the inside of the plastic connector and look good.
(in reply to hurley870)
Post #: 2
RE: Fuseable Link? - 9/26/2008 8:12:42 PM
marck
Status: offline
Yes, I had the fusable link burn out on my 69 Impala once.
As I recall, it was located by the battery, as Mad Mike noted.  A wiring diagram of you car will show it.
It''s easy to replace, but that fuseable link burned out for a reason.  You have an electrical problem that needs to be found and fixed, or the fuse will simply blow again.
183k miles, Blood Red, ''91 RS 305 auto with potential!
(in reply to MadMikeZ28)
Post #: 3
RE: Fuseable Link? - 9/27/2008 12:44:25 PM
franklin01
Status: offline
Just fixed the same thing on my 83 camaro, turns out there was a wire shorting against the firewall of the engine compartment...not sure what the wire went to...but after i removed it i  just taped the end, and that stopped that fusable links from blowing...but again, not sure what the wire goes to, everything seems to be working properly
(in reply to marck)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 3rd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
