possibly a problem?
Login | |
possibly a problem? - 9/27/2008 8:22:27 AM
Ferg
I am having a problem with the ABS inop light. When the light is on everything seems to be fine. But when the light is off. When I start braking it acts all jacked up. I can be stopping to pull in a driveway and the Low Trac light comes on. Then my brake pedal starts vibrating really bad. Then it feels like the car is about to die. The ABS fuse in the box has been removed. The fuse box with the large black ones with the prongs like on a plug for a cord. Can I get a new ABS "fuse" if so how much would it cost?
_____________________________
2005 Dodge SRT-4 Stage 3-SOLD 2003 Ford Mustang COBRA 10th. Anniv.-SOLD 1995 Pontiac Trans Am-current
RE: possibly a problem? - 9/27/2008 8:35:14 AM
Spartan66
thats a relay not a fuse first off, I went to schucks.com and found one for a 95 t/a for 21.99 in under a minute.
RE: possibly a problem? - 9/27/2008 8:35:20 AM
02StanGT
Joined: 9/18/2005 From: Ft. Worth, TX Status: offline
I have to ask this, as a few others have had this problem and it ended up being the problem. Are all the tires the same size?
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF 1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies need to be installed :) www.fquick.com/MrLogger
RE: possibly a problem? - 9/27/2008 8:37:28 AM
Spartan66
he clearly said hes missing the ABS relay.
RE: possibly a problem? - 9/27/2008 8:41:26 AM
02StanGT
From what I read, was he was having problems, then removed it. Sound like he was wondering why he had problems before he removed it. The light shouldn''t be going on/off with it out.
