Throttle body question
Login | |
RE: Throttle body question - 9/28/2008 12:05:12 PM
cbr600rx7
Joined: 5/1/2007 From: Fort Brag NC (some where in iraq) Status: offline
FAST is by far the best both for TB''s and manifolds. Using a upgraded TB on a stock manifold will not give you any gains except maybe 2 or 3 horses at the very top of the power band. The stock intake and TB flow good on stock and mildly bolted applications.
_____________________________
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO
RE: Throttle body question - 9/29/2008 3:22:04 PM
Skippysnax
i have headers, cat back exaust, jet maf, k&n intake, and gutted cats. I still dont have near the power i want, are u guys basically telling me that im at the point where i have to rebuild my engine to get anymore hp? cause thats rediculous
RE: Throttle body question - 9/29/2008 4:35:17 PM
gvmv
quote:
ORIGINAL: Skippysnax i have headers, cat back exaust, jet maf, k&n intake, and gutted cats. I still dont have near the power i want, are u guys basically telling me that im at the point where i have to rebuild my engine to get anymore hp? cause thats rediculous No we are saying that a throttle body is not going to give you the gain worth purchasing it at this time. Looking at your upgrades it''s time for Cam and/or heads if you want more power. The cam is the brain, it doesn''t matter how big the hole is going into the engine if the valves are not opening enough to use it. Throw a cam and some 1.6 rockers/ lt4 knock sensor custom tune. Then you might think about throttle body, but then you should also check fuel system(fuel pump,injectors) to make sure it''s up to more power first. Again back to our point, throttle body at this point is not cost/hp efficient. Do you need to rebuild your engine to get more power, no. There are other upgrades you can do before that.
1993 Camaro Z28 A4 Car Journal - http://slatlin.livejournal.com/ Car Images - http://the-michels.com/gallery/93Z28 http://treasurevalleyf-bodys.com - http://www.fbodyonline.com/
