Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Multiple Problems 98 3800 V6 Auto
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> Multiple Problems 98 3800 V6 Auto Page: [1]
Login
Message << Older Topic   Newer Topic >>
Multiple Problems 98 3800 V6 Auto - 9/29/2008 4:23:54 PM
truerollers
Score: 0
Status: offline
Hello, to start off...  I am new here, hello everyone!  Now to dive right in...
Problem number 1:  The "easy" problem.
Car has a hard time starting.  Especially after being off a while.  Within 10 minutes of running, starts right up.  10mins to a few hours, has to crank a few extra seconds.  After a few hours, especially overnight, have to try several times, with about 30 seconds of cranking to get it to start.  Other than that, car idles fine, runs fine cruising or under load.  I haven''t pressure tested the system yet, but hopefully I will be able to.  I am thinking Fuel Pressure Regulator, and no harm in replacing the fuel filter.  Probably gonna replace the starter while I''m at it...  it''s been stressed pretty bad with this problem. Ideas?
Problem number 2:  The "OMFG THIS POS IS FUBR" problem.
While driving this thing, there is a HORRIBLE noise coming from the car.  I assume its in the bellhousing.  The noise is coming from above the shifter, but behind the engine.  Its a knocking, rubbing, undescribable kind of noise.  It''s definatly not the engine, not the rack and pinion, not the suspension, or the brakes...  although the rotors are warped.  I hear this HORRIBLE UNGODLY noise durring:
Braking, especially as the car gets closer to shifting down to first.
While driving randomly.
Especially when I hit a bump, or many bumps.
It almost sounds like a hollow plastic dragging on rough metal kind of noise...  It really is hard to describe.  Anyway...  Ideas here?  We are thinking torque converter falling to pieces...  but then again, it accellerates and decellerates just fine, outside the HORRIBLE MIND BLOWING noise.
1998 Camaro; 3800; Automatic
_____________________________
Post #: 1
RE: Multiple Problems 98 3800 V6 Auto - 9/29/2008 5:00:37 PM
02StanGT
Score: 0
Status: offline
02StanGT's photo gallery
Problem 2 sounds like a tranny mount.
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF
1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies need to be installed :)
www.fquick.com/MrLogger
(in reply to truerollers)
Post #: 2
RE: Multiple Problems 98 3800 V6 Auto - 9/29/2008 8:59:25 PM
GMDCAMARO
Score: 0
Status: offline
GMDCAMARO's photo gallery
Stan, i get confused with your avatar.  Thats how i know who is who, and yours confuses haha!
97 Camaro RS w/ y87 Package, 18'''''''''''''''' AR Rouges, SSBC Brake Kit, Magnaflow Cat-Back, CAI
(in reply to 02StanGT)
Post #: 3
RE: Multiple Problems 98 3800 V6 Auto - 10/3/2008 3:32:35 PM
truerollers
Score: 0
Status: offline
Problem 1:
Turns out the cat is bad.  Thats part of the no start problem.
The Coolant temp sensor is more than likely bad.
It needs a new ignition coil.
Problem 2:
With bad rotors, vibrations are going into the cabin durring braking and causing the wonderful chevy dash squeek.  But in a real bad way.  Heat shield may be loose but doubtful.  We put the car in the air and ran it to 60mph and stopped it, few times, and not a single noise.
(in reply to GMDCAMARO)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forum >> Camaro Models >> 4th Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
