Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
OIL PAN GASKET
  Printable Version
Camaro Forums >> Camaro Models >> 4th Generation >> V8 Tech >> LT1 Camaro >> OIL PAN GASKET Page: [1]
Login
Message << Older Topic   Newer Topic >>
OIL PAN GASKET - 9/29/2008 6:35:55 PM
TEXASMAN1
Status: offline
i got a leak from the oil pan. how much do you guys think it will cost to get it fixed?
Post #: 1
RE: OIL PAN GASKET - 9/29/2008 6:47:00 PM
SpecterGT260
Black Stig FTW
Status: online
SpecterGT260's photo gallery
are you positive its the oil pan gasket and not something more serious?
i had to loosen my oil pan when I did my cam, and honestly, if i had wanted to just take the bolts all the way out, slide in a new gasket, and retighten it it would have only taken me about an hour.  maybe 100 bucks at a shop for that then?  depends on now they decide to do it i guess.
_____________________________
My Fquick < PM me to get into the camaroforums group
Go check out this months ROTM!
(in reply to TEXASMAN1)
Post #: 2
RE: OIL PAN GASKET - 9/30/2008 1:03:42 PM
TEXASMAN1
Status: offline
im pretty sure thats where its coming from. this mechanic i know had a z28 and he said it was a bitch. i know its leaking fromt he front and i think the bigest leak is at the end of the pan.
(in reply to SpecterGT260)
Post #: 3
RE: OIL PAN GASKET - 10/1/2008 10:53:36 AM
kyphur
Status: offline
kyphur's photo gallery
usually you have to take out the motor mount bolts and lift the engine so the pan can clear the crossmember.  You might get away with putting a block of wood against the transmission pan and lifting it there though.  You usually can''t just loosen the bolts and slide in a new gasket as you have to get the gasket around oil pump and rotating assembly especially if you''re going with a 1 piece gasket.  Usual price is about 300 bucks but that''s around here.
kyph
http://www.kyphurland.com
1974 Type LT Z28
Rebuilt 350ci L82 and th400 trans
All matching numbers
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 4th Generation >> V8 Tech >> LT1 Camaro
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
