Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
problem seperating the tranny from the engine
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> problem seperating the tranny from the engine Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
problem seperating the tranny from the engine - 9/30/2008 3:51:23 PM
94z
Score: 0
Status: offline
    Alright guys i managed to get the engine out of the car with the tranny attached.  Now i have run into a problem seperating them.  Do i have to push the clutch in or something?  I have all of the bolts removed and it will come off of the engine about a inch or so but wont come all the way off, i thought that they would just come apart after removing the bolts.
_____________________________
Golen 383 with TrickFLow heads coupled with lt4 intake and slp lm exhaust
So your honda has 1.6 liters? My Mountain Dew bottle has 2
Post #: 1
RE: problem seperating the tranny from the engine - 9/30/2008 3:57:11 PM
02StanGT
Score: 0
Status: offline
02StanGT's photo gallery
Pull harder?
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF
1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies need to be installed :)
www.fquick.com/MrLogger
(in reply to 94z)
Post #: 2
RE: problem seperating the tranny from the engine - 9/30/2008 4:00:07 PM
94z
Score: 0
Status: offline
    That might be it but I wanted to make sure I didnt need to do anything wit hthe clutch like compressing it.  The engine is still on the engine hoist and my dad and I spent the last hour playing tug o war with it.  Maybe a pry bar?
(in reply to 02StanGT)
Post #: 3
RE: problem seperating the tranny from the engine - 9/30/2008 4:05:56 PM
02StanGT
Score: 0
Status: offline
The clutch shouldn''t need to be depressed. The input shaft is probably being stubborn and stuck in there. Can you look in there to see if anything is hung up for some reason?
(in reply to 94z)
Post #: 4
RE: problem seperating the tranny from the engine - 9/30/2008 6:10:55 PM
94z
Score: 0
Status: offline
    I can see down inside of it, doesnt look like there is anything obviouse holding it in place but then again I wouldnt really know what to look for if there was something there.  Ill try cranking on it again tomarrow and see how it goes.
Post #: 5
RE: problem seperating the tranny from the engine - 9/30/2008 6:24:15 PM
02StanGT
Score: 0
Status: offline
Good luck.
(in reply to 94z)
Post #: 6
RE: problem seperating the tranny from the engine - 9/30/2008 10:42:48 PM
95slvrZ28
Caretaker of the Ban Hamster
Score: 4
Status: offline
95slvrZ28's photo gallery
My only advice: Make sure you''re separating it equally on all sides, if you start to pivot the transmission and not the motor you''ll get torque on the bolts and you won''t be able to slide it, so go straight back. If you''re already doing that...pull harder.
Moroso CAI/Kooks 1 3/4 LT Headers/catted Y/!muffler/Hooker tips. 17X9.5 Chrome Z06 wheels
Exhaust clip: http://www.youtube.com/watch?v=1WArqIB6esM
Post #: 7
RE: problem seperating the tranny from the engine - 10/1/2008 1:50:17 PM
cbr600rx7
Score: 0
Status: offline
Big hammer and a cheater bar
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO
(in reply to 95slvrZ28)
Post #: 8
RE: problem seperating the tranny from the engine - 10/2/2008 5:52:28 PM
deltav
Score: 0
Status: offline
I hope you released the clutch fork. If not, your situation will happen; all bolts off but will only seperate about an inch or so while pulling straight back. If you haven''t, and it won''''t come loose on it''s own, you need to pull down on the clutch fork. There''s an indenture on the bottom of the clutch fork that you need to push in, then down to get it unhooked from the throwout bearing. This is assuming you unbolted your slave cylinder along with the spacer, or else you won''''t even see the clutch fork.
< Message edited by deltav -- 10/2/2008 5:54:30 PM >
''94 Z28 M6:
Performance: CC cam, beehive''s, LT''s, o/r y-pipe, TSP Rumbler, MSD 6a-(vented)cap kit-coil-8.5 wires, moroso CAI, pulleys, !A/C, dyno tune 320rwhp/356rwtq
Suspension: Strano 35mm/22mm swaybars, Umi phb & lca''s, AIS shocks+stiffer spr
(in reply to cbr600rx7)
Post #: 9
RE: problem seperating the tranny from the engine - 10/2/2008 10:45:45 PM
importmd
Score: 0
Status: online
importmd's photo gallery
unbolt the bell housing from the trans, pull back the trans, look inside at the clutch fork, 13mm box end wrench, thats whats holding you back.
08 HD 1200N
01 Tahoe LT
95 Z28 T56
78 CJ 5 Trail Rig
http://www.msnusers.com/newcamaro/shoebox.msnw
(in reply to deltav)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 4th Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
