Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
T-Tops max torque?
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> T-Tops max torque? Page: [1]
Login
Message << Older Topic   Newer Topic >>
T-Tops max torque? - 10/2/2008 2:22:26 PM
CamaroGuyVT
Status: offline
Hey there,
So I have a quick question....
I just bought an 85'' RS with T-Tops. Currently has a 400 small block but I''m looking to beef it up a bit. A buddy of mine just finished building a 383 stroker motor which has approximately 390 HP and 450 ft.lbs. tq. which he''s offered to sell to me for a really good price.
However, when I told him it''d be going into this RS, he said it wasn''t a good idea. He said the motor produced too much torque and would bend the frame since the car had T-Tops. Due to it''s single beam design, it would surely bend over a short time, even if the car has sub-frame connectors.
Does this seem true? The guy is VERY knowledgeable with Camaros, but i''ve personally never heard of this issue with the T tops with only 450 ft/lbs torque. Should I go ahead with the 383 stroker or stick with the 400?
Let me know what y''all think....Thanks!
Post #: 1
RE: T-Tops max torque? - 10/2/2008 3:59:32 PM
Jr. Mechanic
Status: offline
Jr. Mechanic's photo gallery
Well, first off, there really is not a big structual difference between a hard top car and a T top car, its very little, if any.  However, once you start putting out some power, it will twist, causing the T tops to leak (if they dont already.)  Subframe connectors will REALLY stiffen it up, and you should have no problems.
_____________________________
Jr''''''''''''''''s Rides:
1983 Camaro Z28, 1993 Jeep Grand Cherokee, 1997 Plymouth Neon
(in reply to CamaroGuyVT)
Post #: 2
RE: T-Tops max torque? - 10/3/2008 12:52:54 PM
1990CamaroRS
Status: offline
1990CamaroRS's photo gallery
there is litereally almost NO difference between a hardtop and t-top car (pull the headliner off a hardtop car, and the t-top bar is right there in the middle).  subframe connecters will help quite a lot, and if that''s not enough you can always add a roll cage.
quote:
ORIGINAL: CMRO GRL
no no... its against the rules... and if i wanted to look at some, i''d look at my own
major fail.
(in reply to Jr. Mechanic)
Post #: 3
RE: T-Tops max torque? - 10/14/2008 8:05:46 PM
Roy
Status: offline
I''ve welded two sets of subframe connectors into 3rd gen Camaros one hard top and one T-Top. The firmness of the body is noticably increased and the body flex should not be an issue. Do this, you will be amazed. I''d be more worried about breaking a yoke,axle,pinion, or ring gear in your stock rear end than the car twisting with 400hp.
Go for the engine and treat you differential to a new cover with bearing cap supports, this will help it "live" for a while behind the new power until you beef it up.
Good Luck!
Roy
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 3rd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
