free mods for a 3.8
Login | |
free mods for a 3.8 - 10/4/2008 7:12:49 AM
SSV6
I was wondering if there''s any free mods that I can use for my 3.8 until i get the money to do my swap, I''ve heard rumors of a block keeping the throttle body from opening all the way, and other things like that, I just don''t want to take that stuff apart until I know if it''s there for sure. also, the resistor chips that go on the intake, I have tons of resistors laying around and i was wondering what size that is, that''s also a free mod for me.
_____________________________
R.I.P. 1996 Camaro RS White WAYYYY too fast to be a normal V6 99 V6 Convertible
RE: free mods for a 3.8 - 10/5/2008 12:08:46 AM
Spartan66
Sugar in the gas tank... No but seriously your not going to see any huge gains with "free mods" and if your going to swap I dont think its worth it. I mean maybe if you take advantage of those free mods in conjuction with real mods. Youve got to pay to play.
RE: free mods for a 3.8 - 10/5/2008 9:24:25 AM
Camaro 69
And stay away from those intake resistor "chips". They''re a scam. All it does is alter your fuel richness by fooling the computer into thinking that the incoming air is colder than it really is. But the computer just readjusts the fuel mix to how it should be from the readings it gets from other sensors that are further down the line.
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
RE: free mods for a 3.8 - 10/6/2008 5:33:59 PM
JaySan
weight reduction , and you can cut out the bottom of ur air box
< Message edited by JaySan -- 10/6/2008 5:35:36 PM >
[IMG]http://i157.photobucket.com/albums/t71/jaysan_2007/smallwitz06.jpg[/IMG]
RE: free mods for a 3.8 - 10/7/2008 4:13:49 AM
Frechles71
Joined: 3/30/2007 From: Marshallville, Ohio Status: offline
hey SSv6 there are actually a bunch of free mods you can do to these things. There is a list and a how to over at camarov6.com somewhere. I was going to post a link for ya but seems there website isnt working or something right now. Dont listen to these guys. Yea free mods are cheap and dont get you much but you know what; they are fun. You get to spend some time working on your car and, with the economy the way it is in the ****ter, you get to make some mods so it isnt ''bone stock''. Off the top of my head: getting rid of the fins in the air box. I used a dremel and a die grinder. Also helps to open up the oval in the back as much as you can. I cut the bottom of the air box out to get more air in there (doesnt really do much). I also got rid of the silencer. Went to Home depot and picked up some 3" dryer vent. If you want to do it, get the expandable tubing but not the one that comes in a box that looks like flakey aluminum foil. That stuff can fall apart and cause you problems. The kind I got is quite rigid and was laying on a shelf as just a long straight tube. I have had mine on for almost two years and no holes or anything in it yet which is everyones biggest reason to rag on this mod. There are other mods like egr delete, coolant line bypass, etc that you can look up and check out. Goodluck!
RE: free mods for a 3.8 - 10/7/2008 8:20:51 AM
02StanGT
Joined: 9/18/2005 From: Ft. Worth, TX Status: offline
EGR delete doesn''t really do anything as it is not used at idle or full throttle. It is used during cruising, and in addition to emissions it also helps gas mileage.
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF 1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies need to be installed :) www.fquick.com/MrLogger
RE: free mods for a 3.8 - 10/7/2008 1:30:10 PM
Crunchy
Frechles71, Do you have a picture of your engine bay? Everybody says to remove the air baffles under the air lid and replace the silencer but never really explain where it is... I also would like to see how/ where you moved your sensor. Thanks for the ideas!!!
Mods Pacesetter Headers - High Flow Cats Flowmaster Muffler - Custom Exhaust 2 12'''''''' subs - 2 Alpine amps 8 Infinity speakers - y87 Dark tin
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
