Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Help!! Car is stuck at school
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> V6 Tech >> Help!! Car is stuck at school Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Help!! Car is stuck at school - 10/7/2008 1:49:24 PM
SilverBullet5
Status: offline
Hey guys,
So after class I go out to start my car and as I try starting it, it just cranks with no turning over, and if it does turn over, it dies immediately....I''m thinking that it''s obviously the starter, but I don''t know if it could be anything else....Any responses appreciated, i''m stuck at school and I was done an hour ago so I would really like to go home at least knowing what the problem is.
TIA
_____________________________
00 Camaro 3.8
Full Exhaust
Billet Grille
T-tops
Post #: 1
RE: Help!! Car is stuck at school - 10/7/2008 2:04:26 PM
RSSteve
Status: offline
What do you mean it cranks but doesn''''t turn over? They are the same thing... You mean it does''''t fire/ start? Your fuel pump more than likely is shot. when you turn the key do you hear the fuel pump run?
If the starter is turning the engine over then its not bad, its doing its job.
< Message edited by RSSteve -- 10/7/2008 2:05:40 PM >
(in reply to SilverBullet5)
Post #: 2
RE: Help!! Car is stuck at school - 10/7/2008 2:06:54 PM
SilverBullet5
Status: offline
It doesn''t completely start, it just cranks like its trying to start....so you think its fuel pump?
00 Camaro 3.8
Full Exhaust
Billet Grille
T-tops
(in reply to RSSteve)
Post #: 3
RE: Help!! Car is stuck at school - 10/7/2008 2:10:19 PM
Camaro 69
Status: online
What does your gas gauge read, and does it tell the truth?
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
Post #: 4
RE: Help!! Car is stuck at school - 10/7/2008 2:27:36 PM
SilverBullet5
Status: offline
It lies :( it says its full most of the time unless I am idling for a while....I asked about it a while ago and got no response.
00 Camaro 3.8
Full Exhaust
Billet Grille
T-tops
(in reply to Camaro 69)
Post #: 5
RE: Help!! Car is stuck at school - 10/7/2008 3:01:42 PM
Camaro 69
Status: online
So, how long has the gauge been on full since you last filled the tank? Weeks...months?
Eventually "full" is gonna really mean "empty". How do you gauge your tank''s level?
And how do you know it''s not empty now?
Post #: 6
RE: Help!! Car is stuck at school - 10/7/2008 3:06:54 PM
SilverBullet5
Status: offline
Well I filled up this morning and I usually just fill up every time it hits 300 miles.
00 Camaro 3.8
Full Exhaust
Billet Grille
T-tops
Post #: 7
RE: Help!! Car is stuck at school - 10/7/2008 3:42:46 PM
RSSteve
Status: offline
well sounds like your about to fix that problem lol. (fuel pump and sending unit) Can you hear the pump run when you turn the key to the ON position (the position before start)
Post #: 8
RE: Help!! Car is stuck at school - 10/7/2008 3:44:55 PM
SilverBullet5
Status: offline
It''s either the pump or vents that turn on when I do it, i''m about to head back up to school so ill check and report back, i''ll probably just call for a tow now and get it replaced tonight :/ this is not a good way to start the week.
00 Camaro 3.8
Full Exhaust
Billet Grille
T-tops
Post #: 9
RE: Help!! Car is stuck at school - 10/7/2008 3:47:01 PM
Camaro 69
Status: online
OK, you filled up this morning. Either it''s a huge coincidence, or they are related.
I gotta ask a "duh" question, but is there any chance you may have accidentally filled the car with Diesel?
Believe it or not, it can happen. I knew someone who did that unknowingly. Then suddenly his car started "burning oil". Not till after his engine was rebuilt, and still burned oil (Doh), did he discover that there was diesel in the gas tank....ouch!
Or...was there a fuel tanker at the station when you were there? You never want to get gas when a tanker is filling the storage tanks because there could be sediment that can get stirred up and pumped into your car. Your fuel filter could be plugged.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
