Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
bigger wheels = Less HP ?
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> V6 Tech >> bigger wheels = Less HP ? Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
bigger wheels = Less HP ? - 10/7/2008 8:20:38 PM
JaySan
Status: offline
I upgrade from my stock 16 in. wheels to 18 in Z06 wheels. How much rear wheel power am I losing ? I just want to get an idea
_____________________________
[IMG]http://i157.photobucket.com/albums/t71/jaysan_2007/smallwitz06.jpg[/IMG]
Post #: 1
RE: bigger wheels = Less HP ? - 10/7/2008 8:25:26 PM
02StanGT
Status: offline
02StanGT's photo gallery
You wouldn''t lose horsepower. If anything it may be a little slower due to increased rotating mass. I don''t think it would be enough for you to notice, unless your butt is pretty sensitive.
1999 Mountaineer AWD 5.0 - 4300K HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF
1997 RS - 4300K HID lows and 3000K fogs, HPTuner, Bolt-ons... More goodies need to be installed :)
www.fquick.com/MrLogger
(in reply to JaySan)
Post #: 2
RE: bigger wheels = Less HP ? - 10/7/2008 9:05:21 PM
evilkal
Status: offline
evilkal's photo gallery
Mainly all you lose is more gas because, as Stan said... More rotating mass
EDIT: P.S. Stan I have a hypersensitive butt dyno tbh... My car makes exactly 212.29485903759837293 hp to the wheels =D
< Message edited by evilkal -- 10/7/2008 9:06:30 PM >
(in reply to 02StanGT)
Post #: 3
RE: bigger wheels = Less HP ? - 10/7/2008 9:26:12 PM
z28pete
Status: offline
z28pete's photo gallery
You are not going to lose any power but you will lose some effective torque at the rear wheels because the larger wheel diameter, around 12% if you keep the same tire aspect ratio. However; if you mount some very low profile tires that will keep the same outside tire diameter, you will lose nothing power or torque wise, but gain a terrible ride due to the lack of sidewall cushioning.
Pete
(in reply to evilkal)
Post #: 4
RE: bigger wheels = Less HP ? - 10/7/2008 9:26:49 PM
Camaro 69
Status: online
The determining factor is overall weight. Yes the 18" wheels are a larger diameter, but that doesn''t necessarily mean that they weigh more than the 16''s. It all depends on the design. And then consider that there is less sidewall on the 18" tires. So if the tires are relatively the same width as what you have now, they should actually weigh less than the 16" tires. It''s very possible that your new combo could wind up weighing less than your present ones do. Weigh them and see.
Eats Rice and Poops Out Fords
393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
Post #: 5
RE: bigger wheels = Less HP ? - 10/8/2008 4:19:32 AM
Frechles71
Status: offline
quote:
ORIGINAL: Camaro 69
The determining factor is overall weight. Yes the 18" wheels are a larger diameter, but that doesn''''''''t necessarily mean that they weigh more than the 16''''''''s. It all depends on the design. And then consider that there is less sidewall on the 18" tires. So if the tires are relatively the same width as what you have now, they should actually weigh less than the 16" tires. It''''''''s very possible that your new combo could wind up weighing less than your present ones do. Weigh them and see.
Very true! My 16" winter tire/wheel weighs much more than my 18" summer tire/wheel combo.
Not only is the weight less but the overall outer diameter is smaller with the 18" summer wheels. Bigger wheels with low profile tires is the way to go IMO
< Message edited by Frechles71 -- 10/8/2008 4:21:23 AM >
(in reply to Camaro 69)
Post #: 6
RE: bigger wheels = Less HP ? - 10/8/2008 8:13:01 AM
musicman
Status: online
musicman's photo gallery
If you guys want to lift a heavy wheel, grab the solid steel spare out of your hatch.
14.987 with the V6 T5 Camaro in the 1/4
(in reply to Frechles71)
Post #: 7
RE: bigger wheels = Less HP ? - 10/9/2008 9:22:36 AM
RS96LSU
Status: offline
musicman didnt you change the wheels on your car? i thought i remembered you said in some post that you were ditching the vette wheels
(in reply to musicman)
Post #: 8
RE: bigger wheels = Less HP ? - 10/9/2008 12:11:24 PM
musicman
Status: online
lol, which ones? I still have the peeling 17" y2k''s in the garage, and I''ve got 17" and 18" vette wagon wheels on right now. I''ll be doing brand new rims during the summer.
(in reply to RS96LSU)
Post #: 9
RE: bigger wheels = Less HP ? - 10/9/2008 12:44:21 PM
02StanGT
Status: offline
What kind of wheels you plan on getting, Music?
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 4th Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
