Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
v8 into v6 car
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V6 Tech >> v8 into v6 car Page: [1]
Login
Message << Older Topic   Newer Topic >>
v8 into v6 car - 11/17/2003 4:31:08 PM
1995
Status: offline
Has anyone swapped their v6 for a v8? If so, was there any problem, and was their any needed modifications to the chassis?
Post #: 1
RE: v8 into v6 car - 3/9/2005 6:40:23 PM
HandNUloss
Status: offline
I also would like to know this..I have a 1994 v6 camaro and was wanting to upgrade to a v8 plz give any feedback.
(in reply to 1995)
Post #: 2
RE: v8 into v6 car - 3/15/2005 1:50:59 PM
larson281
Status: offline
as far as i know there is no problem in doing that but you will have to change out the wiring harness and the whole drive train
(in reply to HandNUloss)
Post #: 3
RE: v8 into v6 car - 4/28/2005 9:20:13 PM
YoungGun_Mechanic
Status: offline
You guys' generation of cars is beyond me. I take it you all have 4th gen camaros... It all depends on what kind of V8 you are talking about. LS1, LT1, just a normal 4 bolt main 350? See what I mean? LS1's will require alot of work, like stated above. Your suspension/ braking systems are different, your drivetrain (Especially your rearend gears) are a little different. I have seen guys take out an LS1, and its just like how I took out my Fiero engine. You must lift the front cradle (Chassis, including transmission, engine, suspension etc. and lift the car off it, leaving it on the ground. I have never personally seen another V8 in your model of cars, so I can't really suggest on how it would sit, or fit in there. I know the LS1 is extremely tightly located, and there isn't enough room to change spark plugs.... I would have to suggest against doing it, unless you have an LS1 donor car..... Sorry!
(in reply to larson281)
Post #: 4
RE: v8 into v6 car - 7/4/2005 11:47:51 PM
IDLE
Status: offline
I would only want a 305v8 thats all i want to know is if it will fit.
(in reply to YoungGun_Mechanic)
Post #: 5
RE: v8 into v6 car - 8/27/2005 8:54:50 AM
mumu_supra
Status: offline
I herd that you have to change the gas lines and some other stuff(HARD) V6 gas lines are smaller than V8.....
(in reply to IDLE)
Post #: 6
RE: v8 into v6 car - 8/27/2005 2:25:07 PM
z28pete
Status: offline
z28pete's photo gallery
Be careful of what engine you put in which car and try to get it inspected. By Federal law, you can put a newer model engine into an older car, but it must have all the pollution stuff that goes with the new engine, but you are not allowed to put an older model engine in a newer car. Which means you can put a 2000 engine in a 1985 car, but you can't put a 1985 engine into a 2000 car and use it legally on the highway.
(in reply to mumu_supra)
Post #: 7
RE: v8 into v6 car - 8/28/2005 1:04:57 PM
nj85z28
Status: offline
nj85z28's photo gallery
well like you said its because of emmissions issues, and obvously an older motor would have more pollution than a newer one
_____________________________
New Jersey F-Body Owners Association Member
CamaroForums.com Moderator
PontiacTalk.com Moderator
ClubGP Member #22259
(in reply to z28pete)
Post #: 8
RE: v8 into v6 car - 8/28/2005 9:07:25 PM
z28pete
Status: offline
The question of replacing a v6 with a v8 keeps coming around. It can be done, but it is a lot easier and most likely cheaper to just trade the car. It would be nice to have a section for FAQ and spell out the details on what is needed to do this, for the people that really want to do this.
This aside, it does not make much sense to replace the v6 with a 305 when the LT1 is a much better choice.
(in reply to nj85z28)
Post #: 9
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 4th Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5556
spectergt2604089
madmikez284083
95slvrz283115
02stangt2903
74454bb2749
cplthomas2537
bluovlh8er2462
blade2300
spartan662209
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
