wire running
Login | |
wire running - 8/23/2006 11:26:44 PM
redstick1992rs
hi, im a noob at camaros here. i just got new pioneer 6x9, 4x6 and cd player with a bazooka sub and power amp i want to know where is the easiest place to run audio cable and power for both in the car?? i have the bazooka in the very back of the trunk and the power amp i would prefer under the seat or on the left side on top of the gas tank (not screwed in but velcroed)
RE: wire running - 1/1/2007 5:09:04 AM
91 RS
hey man i don't know what modle you got . but i got a 1991 rs and i put my amp in my trunk on top of the. T top mat with velcroe . but i drilled a hole were my wire can go throught to the fuse box and under the panles to the back. i ran a ground fron the T top mounts.. hope i was a little help
RE: wire running - 6/7/2007 4:11:20 PM
dhighway
I also have 91rs, i installed 3 amps under the rear hatch, with a sub box on top can strap it down to the t-top clips. also i recently changed my carpet from gray to black, and bundled all 3 sets of rca,s and ran them down the middle, the shorter the better. And then 4 gauge wire,from the batt, and fused there, along with a 12 gauge remote turn/on wire! down the pass side in shrink tubing. to a distribution box. also if you have a good set of 6x9,s and im sure you do, you should install dynamat along with dynaxorb behind them, sounds incredible. good luck, have fun, and no (short) cuts. Thumbnail Image
Thumbnail Image
Thumbnail Image
Attachment (3)
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
