RE: having issues advancing timing
Login | |
RE: having issues advancing timing - 9/20/2006 8:39:03 PM
DFENS
Wow. I actually hellped someone! That's really cool to me, cause I'm not the best mechanic in the world (I've only recently started small DIY projects on my Camaro, learning things as I go along). Sweet
_____________________________
87 w/305 First, restoring to prettiness. Then... Plans for Boost, T-56 swap,and either Build the 305, or Go for mighty-revving 302 clone and still be faster than a 350
RE: having issues advancing timing - 9/21/2006 9:57:52 PM
z28pete
Vapor coming out steadly in small quantities is normal; when it puffs like an old steam engine, is when you have serious problems.
Pete
RE: having issues advancing timing - 9/22/2006 5:11:59 PM
RatMotor
Vapor coming out of the valve cover holes (or breathers) steadily whether a small or large amount IS NOT normal. It may be common for older engines or those that don't take care of their cars, but it's not normal. The only time vapor should be coming out of the breathers/holes is when they are wet with condensation from the night before or when the engine is fired up first thing in the morning. The engine heat will burn off any moisture inside the engine and the vapor you see is the condensation on the top inside of the valve covers. If there is any kind of steady smoke (it will not be vapor, as vapor is a product of evaporation, not burning) you have bad valve seals, valves that aren't closing all the way (meaning carbon buildup on the valve seats), the engine oil is breaking down because the engine is WAY TOO hot or you have a bent valve. I doubt the latter as you stated the cam had 40,000 on it already so unless you changed timing chains and got the marks mixed up you OK on [no]bent valves. Try this little trick. Get your engine nice and warm. Go to the store or something. When you get back, go grab a spray bottle filled with water. With the engine running at a higher RPM(2500 or more, so you'll need 2 people), spray the water down the venturies (or into the throttle body if injected) and do it liberally. You do need to keep the engine running through this and that's where the second person helps because the engine will try to die. What this does is try to clean off the tops of the valves with the water kind of like rinsing off your lawnmower after 2 summers of lawns, and often (but not always) it will break off the carbon build up on the valves which is a HUGE reason that people get pinging in their engine. If that fails you can always go to your nearest parts store and get some Fuel injector / valve cleaner and add that to your next 2 or 3 gas fill ups. RM
