having issues advancing timing
Login | |
RE: having issues advancing timing - 9/13/2006 10:04:58 PM
z28pete
Well said. Get a timing light & set the initial advance where it is supposed to be. Invest in a Haynes manual for procedure. The ticking you heard is called pinging or detonation. Too much advance tries to make the engine turn in the opposite direction and can cause severe damage.
_____________________________
Pete
RE: having issues advancing timing - 9/16/2006 12:05:05 AM
z28pete
Well, pinging sounds like a bunch of beans rattling in an empty coffe can, detonation sounds like the engine is getting whacked with a ball peen hammer, similiar to a big truck deisel under load.
< Message edited by z28pete -- 9/16/2006 12:06:19 AM >
Pete
RE: having issues advancing timing - 9/16/2006 5:06:37 PM
z28pete
Make sure that your vacuum advance, if you are using one, is working properly, and only advancing spark during low load conditions. You may want to try using some higher octane fuel. If it just pings off idle and goes away under WOT, you should be OK.
Pete
