Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
vacuum problems
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> V6 Tech >> vacuum problems Page: [1]
Login
Message << Older Topic   Newer Topic >>
vacuum problems - 1/13/2004 12:29:50 AM
jeremy lakenes
Status: offline
no hissing noises from my defrost switches when i turn them. nothing moves from defrost to panel to floor or anything where do i start troubleshooting?
Post #: 1
vacuum problems - 3/2/2004 3:23:27 PM
86EOK
Status: offline
are you having problems with your heat too, you may need a blend door. can you hear anything when you move the switch from defrost to heat or blend? if u have a vac leak use a can of carb cleaner to detect them. also located under the hood passenger side fire wall there is a heater connection u should ck. also ck your coolant level, t-stat, heater hoses,bybass hose from water pump and heater core. also ck fuses etc...
are u chasing a heat problem or a vac problem?
(in reply to jeremy lakenes)
Post #: 2
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 4th Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5699
spectergt2604598
madmikez284276
95slvrz283317
02stangt3171
74454bb2749
cplthomas2713
bluovlh8er2494
spartan662459
blade2345
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
