RE: Roll Cage
Login | |
RE: Roll Cage - 10/16/2006 11:07:16 PM
shnormo
Right now I'm building up a 383 aiming for 510 HP with 490 FT/LBS. Iron Eagle Rotating assembly (balanced) -8CC Dished w/vavle releifs floating pistons, Eagle H beam rods, 49CC 230 CFM Dart heads 2.02" intake valves, haven't decided a cam yet, Roller rockers 1.6 ratio, Chrom Moly push rods, NGK Iridium spark plugs, MSD wires, MSD HEI distributor, Holly black fuel pump, still looking for a pressure regulator, 850 CFM carb, Edlebrock Dual Plane performer RPM intake. I'm rebuilding the Turbo 350 with TCI Master race rebuild kit, having the transpump reworked, B&M Shiftkit, hardened steel input shaft, with a 3800 RPM stall speed coverter. Rear axle is a limited slip 2.73:1 ratio right now, I'm going to swap it out to a 3.73:1 so I can still drive it on the freeway.
_____________________________
- Norm http://www.cardomain.com/id/shnormo05 Rebuilding 79 Camaro
