Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Roll Cage
  Printable Version
Camaro Forum >> General >> General Tech >> RE: Roll Cage Page: <<   < prev  1 2 [3] 4   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: Roll Cage - 10/17/2006 2:38:26 PM
shnormo
Status: offline
shnormo's photo gallery
The block nor the heads were decked. with a 62 cc head the pistons are rated at an 11:1 ratio and in sick's compression ratio calculator it came up with the 14.3:1
_____________________________
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
(in reply to GRIFF)
Post #: 21
RE: Roll Cage - 10/17/2006 3:33:04 PM
GRIFF
Status: offline
GRIFF's photo gallery
If you want give me your bore size, head gasket thickness and bore, head chamber size, block deck height(9.025 stock), piston volume +- if they are dished they may be greater than 8cc you gave, I will calculate it for you.
His calculator is real close to mine though(I found it after the post).
< Message edited by GRIFF -- 10/17/2006 3:47:39 PM >
(in reply to shnormo)
Post #: 22
RE: Roll Cage - 10/17/2006 4:12:21 PM
shnormo
Status: offline
4.040" stock deck height, I don't know about the headgasket thickness, 49CC combustion chamber size, -8CC dish piston.
- Norm
(in reply to GRIFF)
Post #: 23
RE: Roll Cage - 10/17/2006 4:41:22 PM
GRIFF
Status: offline
I only came up with 11.7:1. 49 cc head, 9.025 deck, 4.04 bore, 5.7 stroke, -8 cc dish Ill double check it later
Post #: 24
RE: Roll Cage - 10/17/2006 6:03:02 PM
GRIFF
Status: offline
Got about the same with desktop dyno. 0 deck it and you will be at 12.5:1
(in reply to GRIFF)
Post #: 25
RE: Roll Cage - 10/17/2006 7:04:04 PM
shnormo
Status: offline
Thank you much appreciated
- Norm
(in reply to GRIFF)
Post #: 26
RE: Roll Cage - 10/18/2006 3:19:41 PM
GRIFF
Status: offline
Sorry I messed up used the wrong stroke should have been 12.5 @.025 deck/13.5 @0 deck depends on head gasket thinkness, ring lands, true chamber volume. Again sorry about that. GRIFF
Post #: 27
RE: Roll Cage - 10/18/2006 3:37:51 PM
shnormo
Status: offline
It is quite alright. You've been very very helpful.
- Norm
(in reply to GRIFF)
Post #: 28
RE: Roll Cage - 10/20/2006 4:04:41 AM
uncle bill
Status: offline
The expandable foam is a great idea. The 230's are too big a runner for a 383, Won't make any power below 6000RPM, too much air tumbling and not enough airspeed. VP C16 is the best fuel out there for a Rael high comprecssion engine, massive amount of hydrocarbons slowing the burn rate. Hope this helps.
(in reply to GRIFF)
Post #: 29
RE: Roll Cage - 10/20/2006 8:28:04 AM
shnormo
Status: offline
What size runners you think would work better 210 CFMs?
- Norm
(in reply to uncle bill)
Post #: 30
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284180
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
