Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
WTF
  Printable Version
Camaro Forum >> Brand Review >> Engine & Internal >> WTF Page: [1]
Login
Message << Older Topic   Newer Topic >>
WTF - 10/14/2006 7:24:16 PM
z28child
Status: offline
i have a 78 z28 with a 350 in it
with HEI ignition (no contact points)
and i have run into an odd problem causing me to raze the question, WTF?
i replaced the distributor vacuum advance, cap and rotor and now the car will
not start and i dont get any spark. im pretty damn sure its put together properly.
and the "tests" i've done on the coil r telling me the coil is functioning properly.
so if anyone has any idea on why my car wont start (or some tests i can do to figure it out).
i would really really appreciate it.
thanks
Post #: 1
RE: WTF - 10/15/2006 12:45:23 AM
firebird69racer
Status: offline
could be a number of things
did the new cap come with new screws to hold down the coil, and if so did you use them. some need shorter screws
did you install the little carbon tip and spring under the coil
did you install the ground strap that goes from the screw that holds the coil down to where the wires plug into the cap
did you install the rotor on the right way, there is a notch on one side, its easy to get it backwards
did you put the wires on the right side, one is the power and one is for the tack and the cap is marked so you will know which wire goes where
you sure you didnt unplug the pick up when you installed the vac advance
did you install the plug wires in the same position on the new cap as they were on the old one, that is also easy to get mixed up
hope that gives you some help
_____________________________
Wade
http://s198.photobucket.com/albums/aa291/firebird69racer/
(in reply to z28child)
Post #: 2
RE: WTF - 10/15/2006 9:58:40 PM
shnormo
Status: offline
shnormo's photo gallery
Did you put the distributor back the same way it came out? If not, the timing could be to an extreme?
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
(in reply to firebird69racer)
Post #: 3
RE: WTF - 2/2/2007 10:08:57 PM
z28child
Status: offline
turns out one of the wires on the old pole piece inner coil type device was snapped i replaced that and now she purrs and will go above 2500rpm before she couldnt but now boy howdy.
(in reply to shnormo)
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284179
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
