Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Spark Plugs
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> V6 Tech >> Spark Plugs Page: [1]
Login
Message << Older Topic   Newer Topic >>
Spark Plugs - 10/17/2006 1:10:05 AM
zioneffect564
Status: offline
I am really needing to change my spark plugs out in my 95 3.4L but everyone is telling me different things on how to change them. I've called around and they want $375 to change the plugs and wires and i cant do that right now. Some people have mentioned taking the wheel off and going in that way to get to the 3 that are impossible to get to from the top.
Post #: 1
RE: Spark Plugs - 10/17/2006 11:10:19 AM
shnormo
Status: offline
shnormo's photo gallery
I did a 96 camaro i waas able to get the front them mostly from the top. I raised the car enough and put truck jack stand under it and got the rest from under the car. Taking the wheel might be a little easeir. Take out that plastic wheel well shield too. THat's how I did the tune up on my Explorer. Iridium plugs at $11/ea = $66 and ac delco wires cost $50 lol so that is a **** load of labor costs. If it's just a daily drive, just go with double platnums. Don't go with Bosch.
_____________________________
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
(in reply to zioneffect564)
Post #: 2
RE: Spark Plugs - 10/17/2006 11:11:26 AM
z28pete
Status: online
z28pete's photo gallery
You want to fix cars, you have to get dirty. If you can't do the plugs from the top, you will have to try from the bottom, if something is in the way, like a wheel, you will have to remove it.
Whathever you do, use the best material you can afford, so you won't have to do it again.
As for plugs, if you are going to use platinum or irridium tipped plugs, make sure that both tip and ground electrode are of the same material. Your car uses DIS ignition and 3 of the plugs fire center to ground (normal way), and the other 3 fire ground to center (backwards), so if you use standard platinum plugs, 1/2 of them will last for 100K, while the other half won't make 30K.
Pete
Post #: 3
RE: Spark Plugs - 10/17/2006 4:11:52 PM
chadimus06
Status: offline
i jus replaced the plugs in my 94 3.4L and i did all of them from the top. all you need is a couple of extensions and a swivel socket.
(in reply to z28pete)
Post #: 4
RE: Spark Plugs - 10/17/2006 4:21:36 PM
AlfredB18
Status: offline
quote:
ORIGINAL: zioneffect564
For a 3.8L and LS1, both being 90 degree vee-engines with cylinder heads pointing at the shock towers, this may be true.
The 3.4L is easier.
I think the people who quoted you really forgot a 3.4L existed. Tell them to try again.
Post #: 5
RE: Spark Plugs - 10/18/2006 9:29:34 AM
Beninarkansas
Status: offline
I did mine last week. All from the top. Changing the plugs themselves was a breeze. It was getting the old wires off and boots that was a problem. Get new wires before you strart plug change and anti seeze plugs and die elect grease boots. Make sure the engine is dead cold before you start. Takes about a 6 pack to get job done. 1995 3.4L Manual 5 speed. NO Mods.
Post #: 6
RE: Spark Plugs - 10/18/2006 2:51:59 PM
02blackonblack
Status: offline
Good **** please don't spend that on plugs and wires. Personally, I don't know what the 3.4 looks like because I have a 3.8, but it's very simple. You pull em out (not by the wire, obviously, grab the metal). Shove a socket in there and take the plugs out, wrench the new ones back in and that's a done deal for the plugs. As for the wires, those are very simple. Follow the ends to the distributor cap and then back to the plugs, yank and snap. I feel like someone hit me in the balls with a hammer every time I hear someone paying hundreds for simple labor like that.
- 1986 Camaro Iroc-Z
- 2002 Camaro (Full Exhaust System)
(in reply to Beninarkansas)
Post #: 7
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284179
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
