RE: 383
Login | |
RE: 383 - 11/16/2006 9:13:14 PM
uncle bill
Joined: 9/3/2006 From: San Antonio, Texas Status: offline
The prices are high in some places. Boiling should be around $ 40, I feel pressure testing is much vetter on a block than magnafluxing. The block has too many places you can't see with the mag process. Pressure test about $ 75. The bore / hone w/ plates is in line. Install CB/FP about $ 40. Cripe, install the studs yourself. Shotpeening a block is BS. The square deck should be about $ 125. Block clearance is in line. Hope tthis gives Yiu some guidelines. Machine shop work in Texas isn't taxable. sorrry about Pa, but You might check across in OH.
RE: 383 - 11/17/2006 11:03:52 AM
uncle bill
I cannot see how the studs are going to change anything. All they are doing is replacing the existing bolts, not moving the caps around. Change the studs, Torque them down with bearings in place and check the main bearing clearance. Use an inside mike on the bearings and make sure they're round and true and that the clearances are within tolerance. I'm sorry, but I've never had to even align hone after changing onlt the studs, If it needs align honing, it'll need it whether You use studs or not. Think about it, it doesn't make sense that it would distort the caps.........You're just basically changing bolts for studs.
