Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
383
  Printable Version
Camaro Forum >> Camaro Models >> 2nd Generation >> 383 Page: [1] 2 3 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
383 - 10/30/2006 9:23:08 PM
Andross
Status: offline
I've been thinking about rather than getting a crate engine I'm just gonna rebuild mine. It's cheaper and I can afford it much easier! I want to Make my 350 into a 383 stroker. Does anyone know about how much would it cost me to do this? Does this usually turn out well? What is everyones opinion of a 383 in a 79?
_____________________________
Current Project:
1979 Camaro
Post #: 1
RE: 383 - 10/30/2006 9:26:48 PM
shnormo
Status: offline
shnormo's photo gallery
It turns out great. I put $7000 and I can get 510hp at the flywheel. I got a 79 with a TH 350 and 4:10 rear end. It'll haul pretty damn good. There are two types of 383 kits. The one that uses a 5.7" rod (stock 350) and one with a 6" rod. The 6" rod will give you more power due to the increased stroke. You have a variety of pistons to choose from too. I am going with the 54cc cylinder heads to run on pump gas with 210 CFM intake runners. With the 6" rod, you'll need a small base circle cam. Go to http://www.summitracing.com and enter in the motor specs that you're looking for.
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
(in reply to Andross)
Post #: 2
RE: 383 - 10/30/2006 9:51:16 PM
GRIFF
Status: offline
GRIFF's photo gallery
I have seen quite a few that run really well, and they can be done pretty cheap. How much power are you looking for?
(in reply to shnormo)
Post #: 3
RE: 383 - 10/30/2006 9:51:50 PM
Andross
Status: offline
Can I use the 6" Rod with the stock 350 engine? You know how much a rebuild kit would cost if I already have the 350?
Current Project:
1979 Camaro
Post #: 4
RE: 383 - 10/30/2006 9:52:33 PM
Andross
Status: offline
Im looking for nearly 500 HP
Current Project:
1979 Camaro
Post #: 5
RE: 383 - 10/30/2006 9:59:37 PM
81CanuckZ
Status: offline
If it's on a 79 350 you might want to get it off two bolt mains. Take it to a machine shop and get splay bolts machined in. Otherwise you'll have problems. But then it might just be cheaper to buy a crate. Or you could buy an old 350 with 4 bolts.
1997 GMC Sierra SLT 350 Z71 - Daily Driver-Magnaflow exhaust system
1981 Camaro Z28 350 - Project
1964 Impala Ragtop 283 New Chrome, Top, Upholstery - Weekend Cruiser
Post #: 6
RE: 383 - 10/30/2006 10:06:22 PM
shnormo
Status: offline
You can use a 6" rod with a 350, but you'll need CUSTOM pistons. It'll move the wrist pin higher. The 6" rod will be needed to make 500 hp. Definately get a 4 bolt main or make it a 4 bolt with the machine shop.
http://www.chevymania.com/tech/rod.htm
http://www.chevymania.com/tech/383.htm
- Norm
(in reply to 81CanuckZ)
Post #: 7
RE: 383 - 10/30/2006 10:08:17 PM
Andross
Status: offline
Well here is the good thing.. My dad is currently training to take over a local machine shop :D!!
. So All 79s are 2bolt?
Current Project:
1979 Camaro
Post #: 8
RE: 383 - 10/30/2006 10:17:20 PM
shnormo
Status: offline
All 79 Car 350's. If you can get a hold of a truck motor that would be a 4 bolt main with an insainley strong GM steel crank. You can get Mildon bearing main caps. Get those if you don't want to buy a new block. Install and torque the middle ones to spec and then used their included tools to guide the machine drill for the side bolts. The angled ones are better because it distributes the stress over a larger area. Then get it lined bored so the crank will go in straight.
- Norm
Post #: 9
RE: 383 - 10/30/2006 10:26:45 PM
shnormo
Status: offline
http://store.summitracing.com/egnsearch.asp?SearchType=Engine&N=700+4294908216+4294840140+4294889107+4294925054+4294854588+4294832650+115+4294774852
6" rod kits.
- Norm
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 2nd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284180
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
